The Muntjac SDR
Revision as of 19:42, 25 March 2026 by G4EWJ (talk | contribs)
The Muntjac SDR was designed by Brian G4EWJ based on the same dual band AT86RF215 RF chip as the commercially-available CaribouLite SDR.
It is a transmit-only SDR for DVB-S2 DATV on 13cm (QO-100) and 70cm, which uses an RP2040 micro-controller, as used on the raspberry Pi Pico, to provide a USB interface to the Portsdown 4.
The 75 x 30mm board will come without SMA connectors, so that it can optionally be wired into a system for maximum flexibility. Long thread types are recommended.
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
The Hammond 1550P can be used by cutting slots into box and dropping in the Muntjac-4 board vertically.
Muntjac LEDs
There is a main LED near the button and an LED near each SMA socket.
The main LED blinks HI in morse (.... ..) at power up.
IQ Calibration of the Muntjac
Poor IQ balance in an SDR can cause a carrier to be transmitted at the centre frequency of a DATV transmission.
