The Muntjac SDR
Revision as of 13:14, 1 April 2026 by G4EWJ (talk | contribs)
Specifications
The ouput power of the Muntjac is set by a gain parameter in the range 0 - 20, with each step being nominally 1dB and power zero being -15dBm. The shoulders on the output spectrum are always greater than 30 dB down, and are better than that at lower output powers. Approximate output power is shown in the table below.
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
LEDs
To see the live log output from the Muntjac driver on the Portsdown (muntjacsdr_dvb) log into the Portsdown with ssh and type:
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the AT86RF215 which can be adjusted to improve the local oscillator suppression.
Output Filtering
Frequency Accuracy
The AT86RF215 has an externally connected TXCO, with a temperature stability of 0.5ppm and initial accuracy of +/- 2ppm. The high band frequency output should be within a few kHz of nominal.
