The Muntjac SDR
Revision as of 11:31, 16 April 2026 by G4EWJ (talk | contribs)
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
The Muntjac is supplied as a kit with the final assembly step of soldering the output connectors to the PCB required for completion. The SMA connectors are not supplied. If the SDR is to be mounted in a box (it does fit a small die-cast box) right-angle SMAs with long shafts should be used to allow sufficient clearance between the SMA plug and the box. An suitable example connector is this:
https://www.mouser.co.uk/ProductDetail/TE-Connectivity-Linx-Technologies/CONSMA002-L-G?qs=vLWxofP3U2xfxfFnu8BdmA%3D%3D SMA Connector.png Cheaper suitable connectors are available on eBay.
Another Boxing Idea
The Muntjac is included in the latest Portsdown 4 software, so make sure that your Portsdown is up to date using Menu 3 and 'Check for Update'. If the Muntjac is connected to the Portsdown, disconnect it before updating.
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the chip which can be adjusted to improve the local oscillator suppression.
The required register values vary with the power setting, although not very much within each group of four power settings, so calibration values are only required for power settings 0, 4, 8, 16, 20, 24, 28.
Output Filtering
Frequency Accuracy
Problems
