The Muntjac SDR
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
The Muntjac is supplied as a kit with the final assembly step of soldering the output connectors to the PCB required for completion. The SMA connectors are not supplied. If the SDR is to be mounted in a box (it does fit a small die-cast box) right-angle SMAs with long shafts should be used to allow sufficient clearance between the SMA plug and the box. An suitable example connector is this:
https://www.mouser.co.uk/ProductDetail/TE-Connectivity-Linx-Technologies/CONSMA002-L-G?qs=vLWxofP3U2xfxfFnu8BdmA%3D%3D
Another Boxing Idea
The Muntjac drivers are included in the latest Portsdown 4 software, so make sure that your Portsdown is up to date using Menu 3 and 'Check for Update'. If the Muntjac is connected to the Portsdown, disconnect it before updating.
The first time you use each Muntjac device, it needs to be registered so that the Raspberry Pi recognises it at the next reboot. After connecting a "new" Muntjac to your Portsdown 4, select "Output to" and then "Muntjac". If "Output to" is already set to "Muntjac", simply press the "Muntjac" button again. A message will pop up saying "System will reboot now to register new Muntjac. Touch screen to continue". Touch the screen, and after the reboot, your Muntjac is ready for use.
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
Some Muntjacs may be sold with a calibration file, which will be available for download and incorporation into the Portsdown software. However, some may not have been factory calibrated (although they will have been tested). They will function perfectly well for DATV without this file. A tool is under development to enable the Muntjac calibration file to be generated by the user.
The Muntjac calibration file has a file name of the format E46214B063533828.mjo where the E number is the flash ID of the RP2040 chip. A file of the correct format with the correct name in the /home/pi/rpidatv/bin/ folder is automatically read by the Muntjac driver and the settings applied. An example file can be found at https://github.com/davecrump/portsdown4/blob/master/src/muntjac/E46214B063533828.mjo
Output Filtering
Frequency Accuracy
Problems
