The Muntjac SDR
Revision as of 22:20, 18 April 2026 by G4EWJ (talk | contribs)
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
Output Filtering
Frequency Accuracy
Shoulders at various Power Settings
The screen shots below show the effect of the power setting on the level of the shoulders. Shoulders are generally lower on 437MHz for the same power setting.
The rising levels at the edges of the plots are an artefact of the Pluto band viewer.
Problems
