The Muntjac SDR
Specifications
Preparing for Use
Another Boxing Idea
LEDs
Pin 1 of J4 is the square pad and odd numbered pins are along the edge of the board.
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
Output Filtering
Frequency Accuracy
Programming the Microcontroller on the Muntjac
1. Locate the latest compiled firmware file 'muntjac4_pico-1v**.uf2' which will be found here https://github.com/davecrump/portsdown4/blob/master/src/muntjac/muntjac4_pico-1v0b.uf2 and save it to your desktop.
2. Hold down the BT button (the one nearest the SMA sockets) on the Muntjac while connecting it to your PC using its USB port. The Pico Muntjac appears as a USB disk drive on your PC.
3. Copy the .uf2 file onto the USB drive. The Muntjac will recognise the file and immediately update its firmware, reboot and the PC should recognise a new USB COM device. The main LED on the Muntjac will blink in morse as it reboots. This will be 'HI' for firmware version 1v0b and "MJ" plus the last letter of the firmware version for later versions of the firmware.
4. Disconnect the Muntjac from the PC and connect it to the Portsdown. Make sure that the Muntjac is selected as the Output Device and then Select M2, Info. The Muntjac firmware version will be displayed along with the Muntjac Flash ID.
Alternative Method for Programming the Microcontroller
This may be useful if you've built the Muntjac into a box and cannot easily get to its buttons.
1. Plug the Muntjac into a PC and it will appear as a COM port. Note that this may not work through a USB3 hub.
2. Find the COM port number in device manager and open a serial terminal session to that COM port at 1200 baud, with a terminal program such as putty.
3. The COM port will instantly disappear and the Muntjac will then appear as a USB drive.
4. Proceed with step 3 in the section above.
Note that this depends on the software already in the Muntjac being configured to do this. This approach would not work on a blank Raspberry Pi Pico board, which uses the same RP2040 microcontroller as the Muntjac.
Problems
Mixing Options
THIS SECTION IS WORK IN PROGRESS
These notes are to guide experimentation. Some of the high band frequencies are outside the published specification of the AT86RF215 chip (2400-2483.5MHz). The output should be monitored for quality and frequency accuracy.
Any mixer output MUST be bandpass filtered for the required output frequency. This is particularly important for 23cm, where on 1249MHz for example, the required third harmonic of the low band carrier is on 1170MHz.
As both high and low band outputs can be active at the same, this gives some options for using a mixer to transvert to other bands.
The same DATV transmission can be made simultaneously on both bands (but NOT from a Portsdown menu), but either band can output a carrier instead and the third harmonic of the low band output can be used to mix the high band output to various frequencies.
The following frequency ranges are built into the Muntjac driver in the Portsdown, for experimentation. Putting the target frequency into Portsdown will automatically select the correct frequencies for mixing.
| Output | Low | Harmonic | High |
| 3400-3410 | 1010 | - | 2390-2400 |
| 1300-1305 | 395 | 1185 | 2395-2400 |
| 1270-1280 | 404 | 1212 | 2482-2492 |
| 1244-1250 | 390 | 1170 | 2414-2420 |
| 144-147 | 780 | 2340 | 2484-2487 |
| 70.5-71.5 | 805 | 2415 | 2485.5-2486.5 |
| 50-54 | 812 | 2436 | 2486-2490 |
| 28-30 | 819 | 2457 | 2483-2485 |
