PicoTuner Ethernet Interface
PicoTuner photo: G6HFS
Updates, News and Issues
Try these versions if there are problems obtaining an IP address using DHCP: Media:PicoTuneWH_xwh0v3g_UF2.zip
2026-04-26: Added source code for ptwh0v3e.
Quick Start
Connect an Ethernet cable.
Overview
Required Equipment
Firmware Loading
Connect the USB port to a PC.
After the software has been loaded, the Pico can be put into BOOTSEL mode without having to press the Pico buttons. #Getting Into Firmware Loading Mode
Basic Operation
The Base IP Port is 9900.
Reboot.
Finding the IP Address
Ethernet MAC and Host Name
E.g. 28:CD:C1:41:97:2E
E.g. PicoTunerWH-41972E
DHCP
LNB PSU Output
Second LNB PSU Output
Working with a WinterHill
USB Serial Port Connection
On a PC:
On an RPi:
Type:
ls /dev
Type:
dmesg
Type:
Type:
Add a new line:
Save and exit
CTRL-X then Y then ENTER
Uplug and plug the PicoTuner.
Type:
ls /dev
to check that ttyPT0 appears.
On a PC:
On an RPi:
       PicoTuner Broadcast
       Sequence   1294
       Run time   1301s
 Broadcast port   9997
   Net hardware   WIZnet W5500
            MAC   28:CD:C1:44:9A:2E
     DHCP state   Success
Lease remaining   2305s
     IP address   192.168.77.196
       NIM type   FTS4334L
   LNB supply X   HI
   LNB supply Y   absent
       Software   ptwh0v3e-w5500.uf2
           Mode   WinterHill
   Base IP port   9904
            RX5   10496.700T DD0CW
            RX6   10491.501T A71A
netcat -kluv 9997
In a Command Box, type:
ncat -luv 9997
[to@wh] VGX=LOT
To do this from an RPi, type:
Waiting for Ethernet link - 0
Waiting for Ethernet link - 1
DHCP: starting
DHCP: waiting for OFFER
DHCP: REQUEST sent
DHCP: waiting for ACK
DHCP: ACK received
DHCP: +++ SUCCESS +++
Source Code
Media:Ptwh0v3e-source.zip
The main file is picotunewh.c
ptwh0v3e was built by incorporating it into the examples in the WIZnet SDK (software development kit). https://github.com/Wiznet/RP2040-HAT-C
To install the WIZnet examples: git clone https://github.com/Wiznet/RP2040-HAT-C.git
I did have have an install script to build PicoTuneWH on a Portsdown, but that no longer works, possibly due to some of the Raspberry Pi archives being changed, so some experimentation will be required.
Some changes are required to the WIZnet SDK:
Edit the file:
/home/pi/RP2040-HAT-C/port/ioLibrary_Driver/src/w5x00_spi.c
Somewhere near the top, add the line:
#define USE_SPI_DMA
In the routine:
void wizchip_spi_initialize(void)
comment out the line:
spi_init(SPI_PORT, 5000 * 1000) ;
and insert the line:
spi_init (SPI_PORT, 125 * 1000 * 1000 / 4) ;
Duplicate the routine:
void wizchip_initialize(void)
and rename it as:
void wizchip_initialize_ewj (void)
In the routine:
remove the last section:
   /* Check PHY link status */
   do
       if (ctlwizchip(CW_GET_PHYLINK, (void *)&temp) == -1)
           printf(" Unknown PHY link status\n");
           return;
   } while (temp == PHY_LINK_OFF);
It may be necessary to install the compiler for the Pico:
sudo apt install gcc-arm-none-eabi
and possibly cmake
