The Muntjac SDR
The flash chip has a capacity of 16M bytes, the maximum value for the RP2040 microcontroller. This gives plenty of room for software expansion and perhaps storing of transport streams to use as a beacon.
Please put any comments, questions or problems on the BATC Muntjac forum: https://forum.batc.org.uk/viewforum.php?f=148
The latest version of the Muntjac firmware is 1v0p. Please check your version on the Portsdown INFO screen.
As of 2026-11-06, the ADE-30+ mixer is in stock at DigiKey.
Specifications
Preparing for Use
Another Boxing Idea
LEDs
The main LED blinks 'HI' in morse (.... ..) at power up. This is for firmware version 1v0b. Later versions will blink 'MJ' and the last letter of the firmware version. After a few seconds for initialisation, the main LED will light steady.
Pin 1 of J4 is the square pad and odd numbered pins are along the edge of the board.
First Transmission
If you're not familiar with the Portsdown, set the lines starting 'Modulation', 'Freq' and 'EasyCap' as shown and enter your callsign via 'Menu 3' and 'Set Call, Loc & PIDs'. Adjust the frequency as required.
nc -kluv 9979
The status is updated every second and should look something like this:
muntjacsdr_dvb-1v0m Portsdown driver version.
muntjac4_pico-1v0p Muntjac firmware version.
In: videots The driver transport stream input device.
Out: /dev/ttyMJ0 The Muntjac device name.
FR:2486.500 PWR:3 S:333 FEC:2/3 C:4 Main frequency and parameters.
FR:780.000 PWR:26 Carrier This line appears when mixing.
FT:146.500 The target frequency.
Packets Frames Panic Nulls MJ Panic frames are inserted to prevent
In Out Frames SR333 Errors the Muntjac from running out of data.
-------------------------------------- Nulls SR333 are inserted to maintain
4753 176 11 4 0 an output of 333333kS from an input of
====================================== 333000.
MJ0: [Muntjac4-1v0p:E46164855B404B30 (BUFFER_LOW:2046)]
You may occasionally see a BUFFER_LOW message from the Muntjac. Some of the input modes are not completely constant bit rate in the short term, especially the testcard and contest numbers. A panic frame containing a few null packets is sent to the Muntjac to stop the receiver from losing lock.
Lack of Calibration Spikes
IQ Calibration
The Muntjac calibration file has a file name of the format E46214B063533828.mjo where the E number is the serial number of the flash memory chip on the Muntjac. A file of the correct format with the correct name in the /home/pi/rpidatv/bin/ folder is automatically read by the Muntjac driver and the settings applied. The library of files is in the folder /home/pi/rpidatv/src/muntjac. If you would like your calibration file added to this library, please e-mail it to G8GKQ. An example file can be found at https://github.com/davecrump/portsdown4/blob/master/src/muntjac/E46214B063533828.mjo.
Output Filtering
Frequency Accuracy
The AT86RF215 uses an externally connected 26MHz TXCO on the pcb, with a temperature stability of 0.5ppm and initial accuracy of +/- 2ppm. The 2.4GHz output should be within a few kHz of nominal.
When using 8PSK, the requested power level is increased by 2, to maintain the same output power as for QPSK
Programming the Muntjac Microcontroller
1. Download the latest compiled firmware in this zip file onto the PC desktop and unzip it: muntjac4_pico-1v0p-uf2.zip
The unzipping program may put the wanted file muntjac4_pico-1v0p.uf2 into a folder called muntjac4_pico-1v0p-uf2 on the desktop.
2. Hold down the BT button (the one nearer to the SMA sockets) on the Muntjac while connecting it to your PC using its USB port.
or
Plug the Muntjac into the PC and on the Muntjac, hold down the BT button while pressing and releasing the RS button.
The main LED on the Muntjac will stay unlit when in firmware update mode.
3. The Muntjac should now appear as a new drive connected to the PC. Your drive letter may be different. The drive name will be RPI-RP2 and there will be 2 files in it: INDEX.HTM and INFO_UF2.TXT
Drag the muntjac4_pico-1v0p.uf2 file that you unzipped in step 1 above (not the zip file itself, or the folder it was unzipped into), to the RPI-RP2 drive. The transfer should take about 5 seconds.
The RPI-RP2 drive will then disappear and the Muntjac will restart itself.
On the Muntjac, the main LED near the buttons will blink 'MJ' plus the last letter of the new firmware version. The LED will go out for a few seconds while the Muntjac is initialising and then light steady.
The PC may bing-bong, as the Muntjac has now turned back into a COM port, but this can be ignored.
4. Disconnect the Muntjac from the PC and connect it to the Portsdown. Wait until the main LED on the Muntjac is lit and steady.
Make sure that "Output to" on the Portsdown main menu is set to "Muntjac". If this is the first time that this Muntjac has been connected to this Portsdown, while the Muntjac is connected to the Portsdown, change "Output to" to something other than "Muntjac" and then back to "Muntjac". The Portsdown will recognise a new Muntjac and the Portsdown will reboot itself as part of the Muntjac registration process.
When the Portsdown has rebooted and the main LED on the Muntjac is lit and steady, on the Portsdown select "M2" and "Info" and the Muntjac firmware version and serial number will be displayed as shown below.
Alternative Method of Putting the Microcontroller into Firmware Update Mode
This may be useful if you've built the Muntjac into a box and cannot easily get to its buttons.
1. Plug the Muntjac into a PC and it will appear as a COM port. Note that this may not work through a USB3 hub.
2. Find the COM port number in device manager and open a serial terminal session to that COM port at 1200 baud, with a terminal program such as putty.
3. The COM port will instantly disappear and the Muntjac will then appear as a USB drive.
4. Proceed with step 3 in the section above.
Note that this depends on the firmware already in the Muntjac being configured to do this by the SDK (software development kit). This approach would not work on a blank Raspberry Pi Pico board, which uses the same RP2040 microcontroller as the Muntjac.
Updating the Muntjac Firmware Using a Portsdown
If the Muntjac is built into a Portsdown system, it may not be possible to access its USB socket. A procedure is being developed to help with this.
Mixing Options
As both high and low band outputs may be active at the same time, this gives some options for using a mixer to transvert to other bands.
The same DATV transmission can be made simultaneously on both bands (but NOT from a Portsdown menu), but either band can output a carrier instead and the third harmonic of the low band output can be used to mix the high band output to various frequencies.
These notes are to guide experimentation. Some of the high band frequencies are outside the published specification of the AT86RF215 chip (2400-2483.5MHz). The output must be monitored for quality, stability and frequency accuracy.
Any mixer output MUST be bandpass filtered for the required output frequency. This is particularly important for 23cm, where on 1270MHz for example, the required third harmonic of the low band carrier may be only 58MHz away from the target frequency.
The low band carrier power is set at 26, which is nominally +11dBm. If a passive mixer is used, a Level7 (7dBm local oscillator) mixer is recommended. A suitable mixer is a MiniCircuits ADE-30+ (NOT the ADE-30W+, although that may be more suitable depending on your requirements). Mixers in the ADE series can look the same, but have different footprints, so do check carefully that any other mixer is compartible with the pcb. https://www.minicircuits.com/pdfs/ADE-30+.pdf
The high and low band outputs are connected to the RF and LO ports of the mixer, which are specced at 200-3000MHz and the output is taken from the IF port, which is specced at 0-1000MHz. The output is likely to be in the range of the tens of microwatts. The 23cm band is outside the IF range, but still produces a usable output.
The following frequency ranges are built into the Muntjac driver in the Portsdown. Putting the target frequency into Portsdown will automatically select the correct high and low band frequencies for mixing.
| Target | Low | Harmonic | High |
| 3400-3410 | 1010 | - | 2390-2400 |
| 1300-1305 | 395 | 1185 | 2395-2400 |
| 1270-1280 | 404 | 1212 | 2482-2492 |
| 1244-1250 | 390 | 1170 | 2414-2420 |
| 144-147 | 780 | 2340 | 2484-2487 |
| 70.5-71.5 | 805 | 2415 | 2485.5-2486.5 |
| 50-54 | 812 | 2436 | 2486-2490 |
| 28-30 | 819 | 2457 | 2483-2485 |
Fitting and Connecting the Onboard Mixer
Fit the MX101 mixer here, with its pin 1 dot marker close to the thick bar at the south-east of the pcb legend.
An ADE-30+ has been used for testing. Other mixers may look the same, but may have different pinouts.
The mixer inputs are connected to the high and low band outputs of the AT86RF215 by bridging the pairs of rectangular pads shown in the red circles. There is no way to disconnect the SMA outputs.
The green arrow shows the C101 mixer output capacitor, which if factory fitted, will be 100pF 0603. This may be too low, depending on where you're mixing to.
The blue arrow shows the round pad for the centre of an output coax lead. Use the nearby SMA ground pin for the outer.
Using the Third Harmonic of the Low Band for DATV on 23cm
The third harmonic of 418.333 MHz can be used to transmit on 1255 MHz. The third harmonic is about 20 dB down on the fundamental, so good filtering is required. More details will appear here.
The fundamental at 418.3 MHz on the left with the 3rd harmonic on 1255 MHz on the right
Command Line Operation
This gives full control over frequency and power on both high and low band simultaneously and enables Portsdown band viewer to be run at the same time.
Details will appear here.
Muntjac Schematic
Downloadable PDF files will be available shortly.
Muntjac Input/Output Connectors
The 40 pin J101 position will enable the Muntjac to connect directly to a Raspberry Pi. This will provide power and also an SPI connection instead of USB, allowing higher data rates for future development. It is recommended that no connector is fitted here until the required orientation and gender is known.
The 8 pin J3 position can be used for general I/O or to allow future developments to connect a WIZnet Ethernet module for applications that do not require a Raspberry Pi.
The 12 pin J4 position is for general I/O.
3.3v power is available on J3 and J4. The available current is yet to be determined, but likely to be around 100mA.
All Muntjac I/O pins on J3 and J4 are connected directly to the RP2040 microcontroller, so caution should be exercised regarding static and voltage levels. 3.3v is the nominal voltage level.
There are no pins on J3 or J4 that connect to J101.
Problems
The Muntjac may not be seen as a USB COM port when connected to a some USB hubs. The USB3 sockets on the RPi4 are not a problem. However, it will appear as a virtual USB drive for firmware update when connected to a USB3 hub, which is odd.
