PTT and band switching
In order to make the Portsdown transmitter integrated with transmit and receive systems, Pin 40 of the GPIO goes high when transmit is selected and the signals on pins 28 and 35 can be used for band switching. These outputs are used to switch the LO filter and can be used to switch external filter and amplifiers.
GPIO band decoder
The Portsdown team have designed a simple board which can be either constructed on 0.1” perforated board (veroboard) or on a PCB - this can be home etched using the details below or blank PCBs have been ordered and will be available in the BATC shop in Mid March.
We also recommend the use of a Tx / Rx sequencer to ensure your mast head relay has changed over and your expensive pre-amp is de-powered before you start transmitting. Many circuits and pre-built designs are available including this simple single chip design by Ian Waters G3KKD published in CQ-TV 125.
Also rather than use these pins to switch an expensive RF relay on the output of Portsdown, take a look at this simple idea to use a duplexer / triplexer.
