Serit tuner
As of February 2017 the Sharp and Samsung tuners are no longer available and the MiniTiouner project will use a tuner from Serit which covers from 140MHz right through to 2650 MHz without the need for any upconverters. The first prototype was exposed at CAT16 ( images/d/df/MiniTiouner_CAT16.pdf ) by Jean-Pierre F6DZP
Feedback
Please use the BATC forum for any feedback
http://www.batc.org.uk/forum/viewtopic.php?f=15&t=4853
Dual receiver
The FTS4335 FTS4335 MiniTiouner is capable of receiving more than one signal simultaneously; however the BATC hardware and software can only receive one signal at a time. There is provision for a socket on the converter PCB to connect to the second receive output of the FTS4335V for experimentation. F6DZP's dual receive software is still under development and may be available for testing. See his web site at: http://www.vivadatv.org
Filters and pre-amps
To use the FTS4335 MiniTiouner you will need to run Ver 0.6d or later versions of the excellent MiniTioune software. This is available for download from the Viva DATV forum here and will work with Sharp, Eardatek or Serit tuners. You need to register on the Viva DATV forum before being able to download.
Adapter card
Also, due to a different pinouts from the Sharp NIM, the FTS4335 MiniTiouner will also need a simple adapter board to enable it to be plugged in to the MiniTiouner standard hardware.
Brian G4EWJ has designed a PCB and the blank board plus a full set of (leaded) components and the Serit MiniTiouner is available in the BATC shop.
Instructions and Parts List
media:Serit_FTS4335V_Converter_Kit_MTK2_Instructions_v1-04_Parts_Build_A1_v1.zip
