Serit tuner
Revision as of 20:35, 3 March 2017 by G4EWJ (talk | contribs)
As of February 2017 the Sharp and Samsung NIMs are no longer available and the MiniTiouner project will use a NIM from Serit (FTS-4335) which covers from 143.75MHz right through to 2450 MHz without the need for any upconverters. The first prototype was shown at CAT16 ( images/d/df/MiniTiouner_CAT16.pdf ) by Jean-Pierre F6DZP
Feedback
Dual receiver
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Adapter card
Also, due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM will also need a simple adapter board to enable it to be plugged in to the MiniTiouner.
Brian G4EWJ has designed a PCB and the blank board plus a full set of (leaded) components and the Serit FTS-4335V NIM is available in the BATC shop.
Instructions and Parts List
media:Serit_FTS4335V_Converter_Kit_MTK2_Instructions_v1-06_Parts_Build_A1_v1.zip
