Filter Modulator build
Revision as of 16:44, 4 March 2017 by G8GKQ (talk | contribs)
Parts List
Board information - version 1
PCBs supplied before 28 February 2017 are Version 1 and the parts list and schematics are available for download:
Modifications to Improve the Transmitted Spectrum on version 1 boards
The Version 1 boards described above are OK to use on-air as any spurious emissions are about 50 dB below the main transmission, and the modulation "shoulders" will generally be in-band. However there are a few modifications that can be done to improve their output and reduce the level of the "shoulders" at SR1000 and above. The modifications also equalise the levels between low SRs (RB-TV) and higher SRs (1000 and above). These modifications bring the board to "Version 1A" standard. The modifications are described here Filter Modulator Version 1A Modifications.
Board versions
PCBs supplied before 28 February 2017 are Version 1.
Assembled PCBs due to be supplied in Mar 2017 will be at Version 1A (modified version1).
Any blank PCBs delivered in or after March 2017 will be at Version 2 (more details to follow).
Soldering the small ICs
Testing the board
Once you've completed building your own board you will have to test it - we're currently working out the process but the outline will be something along these lines. These procedures assume that you have completed the board and fitted the 5V regulator, either to the heatsink on the board, or an external heatsink.
Do not connect any other modules to start with.
  • Using a variable power supply, with a current monitor in circuit, slowly wind up the supply voltage to the regulator, monitoring the 5V rail (on the output of the regulator). The 5V rail should stabilise at 5V as the supply to the regulator is increased above 7V. The supply current should be about 250 mA (+/- 50 mA). If the 5V rail goes above 5.2V, or the supply current is greater than 300 mA, stop the process and look for faults on the board.
  • Make sure that your ADF4351 is working with your RPi. Select IQ output mode and transmit, and you should be able to receive the carrier on a receiver or measure the frequency with a counter. Then connect the ADF4351 output directly to the filter modulator input.
  • If all is well with the DC tests and the ADF4351, connect your filter modulator board to the RPi. Make sure that you connect the signal and return lines for both I and Q siganls and the filter select lines as these are isolated from the ground on the filter modulator board.
  • Set the RPi to transmit on 1255 MHz at 2MS. Make sure that you have the output mode set to IQ. Set up a receiver (preferably MiniTioune, but a Satellite receiver will work) set up to receive these parameters.
  • Turn the RPi and set it to transmit. You should see a signal on your receiver. If you do not see an increase in signal level, check the output of the ADF4351, and then the output of the filter/modulator. The filter/modulator output should be greater than 4 dBm (4 mW) at 1255 MHz.
  • If you get a signal, but it is not decoding, check the following in order:
- There should be 3.3v p-p 1 MHz (approx) data signals on J01 pins 2 and 4, and J01 pins 1 and 3 should be at ground. - There should be similar 5V p-p data signals on the hot ends of R03 and R04. - There should be 0.6v p-p signals on each of the test points I+, I-, Q+, Q- near U41. - If the I and Q signals are not present, check the DC switching of the SR filters on J02.
  • Adjust balance pots – Select test signal from the console menu. Place a voltmeter on +Q and -Q and adjust pots for 0 Volts - you will have to do this several times to get a true balance.
  • Check for signal received picture on the satellite rxr – you may need to rescan for new signals.
