Serit tuner
Revision as of 21:30, 7 March 2017 by G4EWJ (talk | contribs)
Feedback
Dual receiver
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Adapter card
Also, due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM will also need a simple adapter board to enable it to be plugged in to the MiniTiouner.
Brian G4EWJ has designed a PCB and the blank board plus a full set of (leaded) components and the Serit FTS-4335V NIM is available in the BATC shop.
Instructions, Parts List, Schematic, Silkscreen
Serit_FTS4335V_Converter_Kit_MTK2_Instructions_v1-07_Parts_Build_A1_v1_Schematic_A1_v2_Silkscreen.zip
