Portsdown transmitter FAQ
Revision as of 17:10, 26 March 2017 by G8GKQ (talk | contribs)
  • How do I turn the transmitter off in Touchscreen mode?
  • What do I need to receive a Portsdown transmitter?
When a Portsdown transmitter is fitted with a filter / modulator card and running in normal bandwidth modes (above 1 Msymbol/sec) you will be able receive it on any Free to Air (or FreeSat but not Sky or Freeview) satellite Set top box - if you have a High Definition STB you will be able to receive MPEG-2 and MPEG-4.
However, when it is running in RB-TV modes OR in Ugly mode without the Filter Modulator card, you can only receive it using the Minitiouner USB receiver.  This is a BATC supported project with some home construction needed - the hardware components are available from the BATC shop and the software is a free download from F6DZP see here for more details.
  • Can I use another touchscreen LCD?
Maybe! The Portsdown project only supports the Waveshare screen - that doesn't mean to say others won't work but we can't help you if it doesn't.
  • Can I use a Raspberry Pi 2?
  • Who are the Portsdown team?
  • Do I need to know about Linux or other clever computer stuff to get Portsdown running?
  • Does Portsdown mean BATC will stop selling the DTX1 like they did DATVexpress?
NO - The DTX1 is designed for those who do not want to "build their own" and will still be available in the BATC shop and supported by Antennair through the DTX1 support website. DATVexpress is still available from the DATVexpress website - the reason we stopped selling is in the BATC shop is because the Express team wanted to offer it directly to end users.
  • Is Portsdown MPEG-2 or MPEG-4?
Both - The Rpi hardware encoder runs MPEG-4 and the Portsdown software has an MPEG-2 encoder both of which are used in the Portsdown transmitter.
  • Why doesn't MPEG2 mode work?
MPEG2 mode currently does not work if you have an analog capture device connected (it upsets the numbering of video devices). If you want MPEG2 mode, unplug the analog capture USB and reboot - it should work. It is hoped to overcome this issue with a software change shortly.
  • Why can't I download or update the software?
  • When I type my password, the cursor does not move. Is this right?
  • How do I get out of touch screen back in to console mode?
  • Connect the RPi to the same network as your PC, and use the IP Scanner to find the IP address of your RPi.
Note, if the console menu does not appear and you end up at the Linux Command Line, you can get back to the Main Console Menu by typing: /home/pi/rpidatv/scripts/menu.sh menu
  • Why do I get an Error Message when I try to change my password?
Prior to Software version 201702100, if you had just exited from the touchscreen, attempts to change the password failed. This has now been rectified. Type passwd, press enter and it should work.
  • When I Log-on or start the Console Menu, it goes Straight to the Exit Screen. How do I recover?
If you accidentally enter a space character when entering the frequency or symbol rate, the Menu software fails and tries to exit. Future software versions (after 201703060) will not let you get into this situation. You can recover by typing the command:
cp -f home/pi/rpidatv/scripts/configs/rpidatvconfig.txt.factory home/pi/rpidatv/scripts/rpidatvconfig.txt
at the Linux command line, and then restarting the console menu with the command:
  • Where can I get a diagram of all the Rpi GPIO pins?
