Revision as of 18:33, 31 March 2017 by G8GKQ (talk | contribs)
You can stream video from vMix from a Windows PC and then transmit it using the Portsdown transmitter. This works with the either the Portsdown filter-modulator board or DATV Express.
Use with the Portsdown Filter-Modulator Board (IQ Output)
First install vMix on your PC and make sure that it works with your selected video source. vMix can be downloaded from here: http://www.vmix.com/ The free version handles SD video and is adequate for our needs.
The next step is to install ffmpeg on your PC. Download it from here: https://ffmpeg.zeranoe.com/builds/ Use the release build, 32-bit, static. Unzip the downloaded file and move the files to a folder called ffmpeg on your C:\ drive so that it has the folders bin, , and inside it.
The last installation step on the PC is to create the windows batch file which will control ffmpeg. You can download a working example from here: You will need to make some amendments to this file later, but it will work "out of the box". Save the file to a logical place of your choice.
Use with the Portsdown Software on a Raspberry Pi and DATV Express
work in progress.......
