Revision as of 11:45, 5 April 2017 by G8GKQ (talk | contribs)
You can stream video from vMix from a Windows PC and then transmit it using the Portsdown transmitter. This works with the either the Portsdown filter-modulator board or DATV Express.
Using vMix with the Portsdown Filter-Modulator Board (IQ Output)
The next step is to install ffmpeg on your PC. Download it from here: https://ffmpeg.zeranoe.com/builds/ Use the release build, 32-bit, static. Unzip the downloaded file and move the files to a folder called ffmpeg on your C:\ drive so that it has the folders bin, , and inside it.
The last installation step on the PC is to create the windows batch file which will control ffmpeg. You can download a working examples for 2MS 1/2 and 7/8 FEC from here File:20170331 vMix.zip You will need to make some amendments to these files. Unzip and save the files to a logical place of your choice. Then edit the end of the last (very long) line of the file to replace 192.168.2.111 with the IP address of your Portsdown TX RPi. This IP address is displayed when you change the Portsdown video source to IPTSIN (don't forget to press the space bar to change the selection!).
Now start up vMix and select a video source. Then configure the output, by clicking the cogwheel next to the output label. The settings you need are here:
Next, you need to start one of the batch files that you saved earlier. Double click on the file in Windows Explorer, it should display the Video bit-rate and ask you to press any key. When you press a key, a second window should open giving information about the stream being sent towards the Portsdown TX. The stream is simply squirted at the IP address that you entered earlier - it can be left running and the TX does not need to be on.
Lastly, set up your Portsdown TX with IPTSIN as the input and identical SR and FEC to that set up in the batch file. Select transmit and it should work.
More to follow..............
