Fushicai USBTV007
Revision as of 13:32, 5 April 2017 by G8GKQ (talk | contribs) (Created page with "The Fushicai USBTV007 is the recommended analogue capture device for the Portsdown Transmitter. Other devices may work, but are not so well supported. ===Inputs=== The USBT...")
Inputs
The USBTV007 has 2 video inputs, composite and S-Video. The composite video input is selected by setting the input number in the Portsdown Menu (System Setup, Set-up EasyCap) to 0, and the S-Video input by selecting the input number to 1. In other Linux installations, the commands ? and ? may be used. The audio inputs are common to both video inputs.
Standards
The USBTV007 is capable of capturing PAL or NTSC. PAL is selected by setting the standard number to 6 in the Portsdown Menu, and NTSC by setting the standard number to 0. In other Linux installations the commands ? and ? may be used.
Capture Resolutions
The capture resolution is 720x576 for PAL and 720x480 for NTSC. 1440 bytes are captured for each line in YUYV format.
Device Identification and Linux Driver
The USB Device ID (from dmesg) for the Fushicai is 1b71:3002; its name is "Fushicai USBTV007 Audio-Video Grabber" and it uses the usbtv Linux Driver.
Use with vMix
The Fushicai USBTV007 also works well with vMix on Windows 10. Simply connect the device and it will load the correct driver. The input settings for PAL, composite are shown here:
File:vMix Input.jpg
for NTSC select 720x480 and NTSC 29.97p.
