Serit tuner
Revision as of 12:02, 2 May 2017 by F6DZP (talk | contribs)
As of February 2017 the Sharp and Samsung NIMs are no longer available and the MiniTiouner project will use a NIM (or tuner) from Serit which covers from 143.75MHz right through to 2450 MHz without the need for any upconverters.
If none of the above apply, you don't need one!
2 versions of the Serit NIM!
Just to confuse the issue there are now 2 versions of the Serit NIM!  Both types work with the new Version 2 MiniTiouner PCB and adapter card for the Version 1 PCB.
The only difference between the FTS-4335V, which was sold in the BATC shop before before April 2017, and the FTS-4334L sold after May 2017 is the addition of an internal amplifier or booster stage before the demodulator chip.
The units can be identified by the model number, which is printed on the opposite end of the unit to the F type connectors.
Serit FTS-4335V (sold before April 2017)
To overcome the lack of the booster, an additional satellite line amp can be used in front of the tuner.
Data sheet of Serit 4335 NIM File:FTS-4335 Series_F2.pdf
Serit FTS4334L (sold after May 2017)
The FTS-4334L unit has a built in booster and will not require an external line amplifier.
Datasheet of Serit 4334L NIM File:FTS-4334L Series_F1.pdf
Serit adapter card
To use either Serit NIM with the MiniTiouner, you will need to run Ver 0.6d or later versions of the excellent MiniTioune software. This is available for download from the Viva DATV forum here and will work with Sharp, Eardatek or Serit NIMs. You need to register on the Viva DATV forum before being able to download.
MiniTiouner version 6 or later also allows you to select which of the two antenna sockets is used on the Serit NIM, allowing one of two antennas / converters to be connected.
NIM pinouts
If, rather than use the adapter PCB, you want to attempt to hardwire the Serit tuner in to the version 1 PCB (why?), the pin differences between Sharp and Serit are as follows:
Filters and pre-amps
Dual receiver
The Serit NIMs are capable of receiving more than one signal simultaneously; however the BATC hardware and software can only receive one signal at a time. There is provision for a socket on the converter PCB to connect to the second receive output of the NIM for experimentation. F6DZP's dual receive software is still under development and may be available for testing. See his web site at: http://www.vivadatv.org
