MiniTioune software
Revision as of 06:22, 12 May 2017 by G8GTZ (talk | contribs)
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software.
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner. The files is located here: Minitioune v0.6d download
Download the zip file and extract to a folder under your root or c:\ directory. You should have the following files in your directory:
The following files are in the directory:
* "readme.pdf" - gives the latest information and a step by step guide to using MiniTioune software version 6d
* "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - A program to run at first installation to check you have installed all the drivers and filters needed to run MiniTioune
* "install_usrc_ax_winXP.exe" - you will need to run this for all versions of Windows (not just XP) to install the usrc filters
Software Installation
