MiniTioune software
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software. The files is located here: Minitioune v0.6d download
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner.
Software Installation
- Download and install the D2XX drivers 2.12.24 found at http://ftdichip.com/Drivers/D2XX.htm. There's a link in the right column for a setup executable.
- Download and install LAVfilters CODECs from here http://www.videohelp.com/software/LAV-Filters
- Plug in your MiniTiouner hardware and let the USB drivers install.
- Run the MiniTiouner tesst program - "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - it should pass on all sections.
- You are now ready to run the main MiniTiouner_v0.6d program.
For a very comprehensive guide on the software installtion, see the paper written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
- A satellite signal from your domestic sattelite dish.
- A local DATV signal from Portsdown (Ugly mode is fine) or any other DATV transmitter - a short piece of wire in the tuner input socket will probably pick up enough signal but be careful - there maybe DC volts on the socket.
- An off air DATV signal from your local repeater or "buddy down the road" (did I really write that!) - make sure you have a filter and line amplifier between your pre-amp and tuner input.
- Signal frequency - you will need to know L band signal frequency coming out of the LNB or direct amatuer band frequency - eg 1255MHz or 1563 MHz
- DVB mode - DVB-S or DVB-S2
- The Symbol Rate or SR - this will probably be listed as MegaSymbols - eg 2Ms or 27Ms - you will need to convert this to kS - eg 2000 or 27000
- The FEC rate - this will be written in the form 1/2 or 5/6
Start the program and you should see the "Please wait 10 seconds message" and then the following screen:
- Symbol rate (SR) - type the symbol rate directly in to the top left green box. (Note this should be the SR in kilosymbols in the following form - 02000 for 2Ms, 00250 for 250kS or 27000 for 27Ms)
- Frequency - type directly in to the top right green box. (Note this should be the L band frequency in the following form - 01255000 for 1255MHz. if it is not the correct format the box will be greyed out).
- FEC - tick the box to match the FEC you are running.
- DVB mode - tick the corect mode box. All DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER and the Verberti error bar graph should go green.
You can edit the miniTioune.ini file in the download directory to configure the preset buttons for commonly used parameters.
To do this, first save a copy of the file on to your desktop - this is so you can always go back when you mess up! Then double click the file and it should open in wordpad.
More to follow.....
