Revision as of 08:16, 14 May 2017 by G0MJW (talk | contribs)
Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page and the Serit tuner described here.
Mike, G0MJW, has written some instructions on building and testing the board.
File:Notes on building the BATC v2 Minitiouner.pdf
Setting up the hardware
The design uses a MP1584 Buck Converter Step Down Module to reduce the input, which can be in the range 6-20V down to 4V. Using a switching converter significantly reduces the generated heat. Optionally a 3.7-5.5V supply can be used instead, bypassing the converter Three low drop out linear voltage regulators are used to regulate the digital 3.3V and 1.2V and analogue 3.3V supply rails. Linear regulators and extensive filtering are used to ensure low noise for maximum RF performance.
Parts list and schematic
The parts list and schematic can be downloaded here:
Note the 22uF electrolytic capacitors on the regulators are High ESR types chosen to minimise oscillation - substitute at your peril! Ceramics can be used instead but through hole 22uF ceramics are expensive.
File:SERIF.pdf
File:Seritpartsv3.xls
On the air
