Jump to navigation
Jump to search
The latest Software for the Portsdown Transmitter is version 201704160 (the version is the issue date with an added 0-9 serial).
Supported hardware
- Raspberry Pi 3 Model B, with or without a 3.5 inch diagonal Waveshare touchscreen.
- Alternatively, the TX can be controlled over the network from another computer.
- The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator.
- Video input from an EasyCap type USB capture device and from a Pi Camera.
Outputs
Currently the Portsdown s/w will output to:
- Control a DATV Express in DVB-S mode.
- Stream to RTMP server such as batc.tv (see restrictions below)
Modes
- In DATV Express mode, it will transmit MPEG-2 or H264 picures from the RPi Camera at 125 KS/s - 4 MS/s
- In streaming mode, it will send RPi Camera pictures and USB dongle sound to the BATC Streamer, or to any other compatible streamer.
- With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 500 KS/s.
Issues
If an EasyCap device is plugged in, some Pi Camera modes do not work.
Future Enhancements
- Streaming (with sound) from an external video input (EasyCap)
- Implement fix for DigiThin mode and test it.
- Provide a shutdown option from the touchscreen
- Adjust the Test Card sizes
- Display transmitted image on the LCD in all modes
- Add sound channel to H264 video modes
Version history
Last updated 22 May 17. DGC
