Revision as of 09:57, 15 July 2017 by G1XIE (talk | contribs) (formatting sedit)
You can stream video from vMix from a Windows PC and then transmit it using the Portsdown transmitter. This works with the either the Portsdown filter-modulator board or DATV Express.
Using vMix with the Portsdown Filter-Modulator Board (IQ Output)
The last installation step on the PC is to install the windows batch file which will control ffmpeg. You can download it from here File:VMix2Portsdown.zip Unzip the file and save the and save the vMix2Portsdown.bat file to a logical place of your choice. You will need to make some amendments to the file; do this by right-clicking and selecting edit. Near the top of the file replace the callsign G8GKQ with your callsign; then replace the IP address (192.168.2.111) with the IP address of your Portsdown TX RPi. This IP address is displayed when you change the Portsdown video source to IPTSIN (don't forget to press the space bar to change the selection!). You may want to adjust the aspect ratio of the output. This is done by editing the line...
Save the file.
Next, start the batch file that you edited earlier. Double click on the file in Windows Explorer, and it should ask for the Video bitrate and FEC, then ask you to press any key. When you press a key, a second window should open giving information about the stream being sent towards the Portsdown TX. The stream is simply squirted at the IP address that you entered earlier - it can be left running and the TX does not need to be on.
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
