The project, which was featured in the June issue of the RSGB's Radcom magazine, involves some basic construction and is based around a Raspberry Pi with a touchscreen, an external local oscillator and a filter modulator card available from the BATC shop - outline specifications are as follows:
• Frequency coverage of the 71, 146 MHz, 437 MHz and 23cms ATV bands (13cms available at reduced output)
Note - the Portsdown project has evolved since the original articles were written and now defines just the Raspberry Pi based transmitter - there is no Portsdown receiver project although it is possible to add an RTL dongle based monitoring receiver. The MiniTioune USB receiver project is the recommended receive solution for all DATV transmissions including the Portsdown transmitter.
System overview
Touch screen control
Modulator and Filter board
The output from the Rpi is connected to the Filter Modulator board which modulates the RF carrier and produces the DVB-S DATV signal - Blank PCBs and fully assembled boards are available from the BATC shop).
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap USB dongle and a USB sound card / dongle - all these are readily available from ebay and Amazon.
Next steps?
Or if you want to print off an overview of the project, we've produced a File:Portsdown Brochure V3.pdf 2 page introductory brochure which also includes a spec sheet for the Portsdown transmitter.
Finally TXfactor have produced a great video introducing and explaining Portsdown and ATV in action - take 15 minutes to watch it here.
