The latest Software for the Portsdown Transmitter is version 201707222 (the version is the issue date with an added 0-9 serial). The Release note for the latest software is here 201707221 Release Note.
Supported hardware
  • The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator.
  • Video input from an EasyCap type USB capture device and from a Pi Camera.
Outputs
Currently the Portsdown s/w will output to:
  • Control a DATV Express in DVB-S mode.
  • Stream to RTMP server such as batc.tv (see restrictions below)
Modes
  • In streaming mode, it will send RPi Camera pictures and USB dongle sound to the BATC Streamer, or to any other compatible streamer.
  • With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 500 KS/s.
Future Enhancements
  • Implement fix for DigiThin mode and test it.
  • Add sound channel to H264 video modes
Version history
  • Version 201704030 Enabled IPTSIN mode and the transmission of contest numbers without a camera.
  • Version 201704050 Update package lists before upgrade (bugfix for 201704030)
  • Version 201704080 German Menus. Waveshare B display support and TonTec selection bug fix
  • Version 201704160 Revised boot-up procedure, Display IP Address on splash screen. Update new build Jessie baseline.
  • Version 201705200 Enabled the Pi Cam auto-shutter and improved the Shutdown button functionality.
  • Version 201705301 Added a second Touchscreen menu with a shutdown button and enabled Contest mode operation from the touchscreen
  • Version 201706301 Adds a number of menu options and the ability to run beta software using a recompiled version of ffmpeg.
  • Version 201707120 Adds a PAL composite video output mode from the RPi and corrected the test card sizes.
  • Version 201707222 Adds the ability to transmit MPEG-2 and stream from an EasyCap. Video and sound switching is provided.
  • Version 201707311 Adds an Info screen on Menu 3, and sound pass-through in "Vid Out" mode.
Last updated 1 August 2017. DGC
