MiniTioune software
Revision as of 16:26, 21 August 2017 by G8GKQ (talk | contribs)
Software Installation
Connecting the hardware
It is absolutely essential you use a high quality cable or the program will frequently freeze and crash with no warning - the recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
  • DVB mode - DVB-S or DVB-S2
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto.
Testing the MiniTioune using a Sky Satellite Signal
You can use the signal from a Sky Satellite dish with a Universal LNB (frequencies will be different for a "Wideband" LNB) to test your MiniTioune as follows:
Place a jumper on J3, which is near the 12v power socket. Check that there is now 12v on the upper NIM F socket. Connect the upper NIM socket to a Sky dish. Start the MiniTioune software. In the frequency setting area in the top left of the screen, put 09750000 into the OFFSET box. Click the PLUS / MINUS indicator next to it so that it shows MINUS. Put 10758000 into the FREQ box. Put 22000 into the SR box. Further down from the FREQ box, below the frequency buttons, check that DVB-S and Fplug-A are selected.
You should get ITV in the video box.
There are several channels on each Sky transponder and these should appear on the buttons at the top right of the screen, below PIDs. A 12v supply will select vertical transponders. Use 12v rather than 13.8v, to stay below the switching threshold for horizontal transponders. Other transponder frequencies can be found at https://www.lyngsat.com/Astra-2E-2F-2G.html The symbol rate (SR) and DVB-S / DVB-S2 setting may need to be changed for other transponders.
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
More to follow.....
