5.6 GHz
Frequency choice
GB3KM has a licenced input on 5665 MHz and this has been chosen as the primary ATV operating frequency.
The FPV equipment receive and transmit frequencies are set using DIP switches, and most tune to this frequency but care needs to be taken when selecting equipment to make sure it does cover this frequency. Example channel tables are shown at the bottom of this page.
Equipment
Mounting the equipment
Transmit amplifiers
Antenna change over relays
Reverse SMA
Antennas
Video equipment
Rx
Video squelch defeat
There are a number of circuits around to defeat the squelch:
  • Syncsmurf by PE1RQM - kits are available details on the webpage here.
  • Video sync processor – CQ-TV 129
Or any video sync processor may be useable.
Tx
On the air
Activity hot spots
Know users include:
  • Ludlow, Shropshire = G8XYJ
  • Yorkshire = G8BYN
More information
Technical information
SM201R
S meter output
Tx and Rx perfomance
Channel Listings
And this is a table from another manufacturer:
