Jump to navigation
Jump to search
The latest Software for the Portsdown Transmitter is version 201710081 (the version is the issue date with an added 0-9 serial).
Supported hardware
- Raspberry Pi 3 Model B, with or without a 3.5 inch diagonal Waveshare touchscreen.
- Alternatively, the TX can be controlled over the network from another computer.
- The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator.
- Video input from an EasyCap type USB capture device and from a Pi Camera.
Outputs
Currently the Portsdown s/w will output to:
- Control a DATV Express in DVB-S mode.
- Stream to RTMP server such as batc.tv (see restrictions below)
Modes
- In DATV Express mode, it will transmit MPEG-2 or H264 picures from the RPi Camera at 125 KS/s - 4 MS/s
- In streaming mode, it will send RPi Camera pictures and USB dongle sound to the BATC Streamer, or to any other compatible streamer.
- With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 500 KS/s.
Future Enhancements
- Implement fix for DigiThin mode and test it.
- Display transmitted image on the LCD in all modes
- Add sound channel to H264 video modes
Version history
- Version 201705301 Added a second Touchscreen menu with a shutdown button and enabled Contest mode operation from the touchscreen
- Version 201706301 Adds a number of menu options and the ability to run beta software using a recompiled version of ffmpeg.
- Version 201707120 Adds a PAL composite video output mode from the RPi and corrected the test card sizes.
- Version 201707222 Adds the ability to transmit MPEG-2 and stream from an EasyCap. Video and sound switching is provided.
- Version 201707311 Adds an Info screen on Menu 3, and sound pass-through in "Vid Out" mode.
- Version 201708150 Adds dedicated repeater streaming modes and video still capture.
- Version 201710081 Adds RTL-SDR functionality and keyed transmit.
Last updated 12 October 2017. DGC
