Portsdown Signal Generator
The next software release will include the capability to use the Portsdown as a basic signal generator covering 54 MHz to 4.2 GHz.
Starting the Signal Generator
On the Configuration Screen:
The ON button enables the RF output. The OFF button stops the RF output. The EXIT button terminates the Signal Generator and restarts the Portsdown DATV Transmitter. The Set Freq Button switches to the second screen (see below).
The next line shows the demanded frequency, and the following line the approximate output level. The attenuator button is to allow for the future use of an external software-controlled attenuator of the PE43703 or PE4302 type available from eBay. The specific type of attenuator is set in the siggencal.txt file (see below). The support for these attenuators is not implemented yet, but is planned for the near future. Similarly, the Mod button is planned to switch on QPSK modulation in Portsdown or Express modes in the future, but is not yet implemented.
ADF5355
Audio
Pi RF
This output is not implemented yet, but the intention is that the Raspberry Pi will be able to generate a signal below 54 MHz on a GPIO pin in a similar manner to the QPSKRF (ugly) DATV mode. This capability will use F5OEO's RPiTX software.
ADF4351
This is implemented, and uses the ADF4351's second output to provide a CW signal in the range 54 MHz to 4.29 GHz. The upper limit is currently 4.29 GHz because of limitations in the 3rd party software driver used by the ADF4351 (which can reach 4.4 GHz). The level is typically between -12 dBM and 0 dBm and is adjustable in 4 steps of approx 3 dB.
Portsdown
This is also implemented, and control the output of the Portsdown Filiter-Modulator board to provide a non-adjustable output level of up to 10 dBm depending on frequency. When selected, this output sets the band switching of the Portsdown so that the VCO filter is switched out of circuit and the output is always switched to the 1255 MHz output socket. The VCO level is always set to maximum to ensure the highest output levels possible at frequencies over 2 GHz.
Express
This output is not implemented yet, but the intention is that the Portsdown Signal Generator will be able to control a DATV Express board as a signal generator.
Control of the frequency and (where possible) output level is from the Frequency Screen.
Frequency Screen
Frequency Control
The small size of the buttons has highlighted some issues in registration between touchscreens and displays. It is hoped to provide a calibration utility for the and the Portsdown DATV transmitter soon.
Level Control
The Mod button is planned to have the same functionality as the Mod button on the Configuration Screen but is not yet functional.
