Portsdown Signal Generator
Software release 201710280 introduces the capability to use the Portsdown as a basic signal generator covering 35 MHz to 4.2 GHz.
Starting the Signal Generator
The Portsdown can be set to boot directly into the Signal Generator and turn the output on (using the saved settings). This capability can be enabled from the Setup, Autostart menu on the console.
There is an unresolved issue with the software appearing to freeze with the BATC Logo on the screen after switching back and forth between the Signal Generator and the DATV transmitter more than 3 times. Normal service can be restored by rebooting the RPi.
On the Configuration Screen:
The ON button enables the RF output. The OFF button stops the RF output. The EXIT button terminates the Signal Generator and restarts the Portsdown DATV Transmitter. The Freq Button switches to the second screen (see below).
The next line shows the demanded frequency, and the following line the approximate output level. The attenuator button is to allow for the future use of an external software-controlled attenuator of the PE43703 or PE4302 type available from eBay. The specific type of attenuator is set in the siggencal.txt file (see below). The support for these attenuators is not implemented yet, but is planned for the near future. Similarly, the Mod button is planned to switch on QPSK modulation in Portsdown or Express modes in the future, but is not yet implemented.
ADF5355
Audio
Pi RF
This output is not implemented yet, but the intention is that the Raspberry Pi will be able to generate a signal below 35 MHz on a GPIO pin in a similar manner to the QPSKRF (ugly) DATV mode. This capability will use F5OEO's RPiTX software.
ADF4351
This is implemented, and uses the ADF4351's second output to provide a CW signal in the range 35 MHz to 4.29 GHz. The upper limit is currently 4.29 GHz because of limitations in the 3rd party software driver used by the ADF4351 (which can reach 4.4 GHz). The level is typically between -8 dBM and +4 dBm and is adjustable in 4 steps of approx 3 dB. The exact output level varies (plus or minus 2 dB or so) depending on the termination of the other ADF4351 output port. The displayed output level is unable to take account of this variation.
Note that, below 2.2GHz, the output of the ADF4351 is a square wave and so will have a high 3rd harmonic content. If the filter modulator board is still powered up, it will still output on the ADF4351's frequency at a higher level. In some cases, when being driven by signals over 2 GHz at the highest ADF4351 output level, the filter-modulator board will oscillate in the 750 MHz region.
The frequency displayed on the touchscreen is the "demanded frequency". Due to limitations in the Analog Devices software driver being used, the generated frequency will step at intervals of about 1/500,000th of the selected frequency. For example, the step at 1240 MHz is about 3KHz.
Portsdown Output from Filter-Modulator Board
This is also implemented, and currently controls the output of the Portsdown Filter-Modulator board to provide a non-adjustable output level of up to 15 dBm between 50 and 1500 MHz. Note that this output has a reasonably high 2nd and 3rd harmonic content. The selectable frequency is limited to the range 50 - 1500 MHz because the output level is unpredictable outside this frequency range.
This output is at a higher level (though over a more limited frequency range) than the direct CW output from the ADF4351. When the switchable attenuator and modulation options are implemented, this output is also intended to be used to adjust the Portsdown transmitter to the correct level for driving a PA without distortion. The modulation will be 333KS, allowing the transmitted spectrum to be viewed on an RTL-SDR and PC for adjustment.
Whilst selected without modulation, this output sets the band switching of the Portsdown so that the VCO filter is switched out of circuit and (if an RF output switch is in use) the output is switched to the 1255 MHz output socket. Additionally, the IQ filter is set to 125 KS and the I and Q lines are set to 0v. The VCO level is always set to maximum to maximise the final output level. The displayed output level is calibrated for a typical Portsdown filter-modulator board without the RF output switch board in-circuit. The RF output switching board induces losses of about 1.2 dB at 50 MHz, 1.6 db at 146 MHz, 1.9 dB at 437 MHz and 3.0 dB at 1255 MHz.
In future, when selected with modulation, the Portsdown DATV transmitter will be activated at 333KS with the appropriate settings for the selected frequency.
Express
This output is not implemented yet, but the intention is that the Portsdown Signal Generator will be able to control a DATV Express board as a signal generator.
Control of the frequency and (where possible) output level is from the Frequency Screen.
Frequency Screen
Frequency Control
The small size of the buttons has highlighted some issues in registration between touchscreens and displays. It is hoped to provide a calibration utility for the and the Portsdown DATV transmitter soon.
Level Control
The Mod button is planned to have the same functionality as the Mod button on the Configuration Screen but is not yet functional.
