Output Attenuator
Attenuator Types
Attenuators based on the PE4302, HMC1119 or PE43703 (preferred) are supported. The PE4302 and PE43703 types are readily available on eBay for under £20. The preferred type is the PE43703 illustrated here:
Data sheets are available at these links: http://www.psemi.com/pdf/datasheets/pe4302ds.pdf http://www.psemi.com/pdf/datasheets/pe43703ds.pdf http://www.analog.com/media/en/technical-documentation/data-sheets/HMC1119.pdf.
Preparation
As supplied, the eBay pre-built attenuator boards are generally configured for control by DIP switches, not by a Raspberry Pi. NOTE THAT IF CONNECTED WITHOUT MODIFICATION THEY MAY KILL YOUR RASPBERRY PI! The modification details for the PE43703 are details here. Please could a PE4302 owner publish similar information??
There are 3 signal lines used to program the PE43703: LE (Latch Enable), CLK (Clock) and Data. For DIP switch programming the LE line is connected to +5v. This line needs to be disconnected from +5v and connected to the external programming pin. Referring to the picture below (pre-modification)
