PTT and band switching
Band outputs
GPIO band decoder
PTT steering
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
David M0YDH shows Ian's design in operation:- G8ADE RELAY SEQUENCER VIDEO and an updated version with extra relay for Portsdown PTT band switching.
Summary of GPIO connections
Pin No | BCM No | Wiring Pi | RPi Name | Primary Use | Secondary Use |
1 | - | - | 3.3v | ||
2 | - | - | 5v | ||
3 | 2 | 8 | SDA1 | ||
4 | - | - | 5v | ||
5 | 3 | 9 | SCL1 | ||
6 | - | - | 0v | ||
7 | Example | Example | Example | Example | Example |
8 | Example | Example | Example | Example | Example |
9 | - | - | 0v | ||
10 | Example | Example | Example | Example | Example |
11 | Example | Example | Example | Example | Example |
12 | Example | Example | Example | Example | Example |
13 | Example | Example | Example | Example | Example |
14 | - | - | 0v | ||
15 | Example | Example | Example | Example | Example |
16 | Example | Example | Example | Example | Example |
17 | Example | Example | Example | Example | Example |
18 | Example | Example | Example | Example | Example |
19 | Example | Example | Example | Example | Example |
20 | - | - | 0v | ||
21 | Example | Example | Example | Example | Example |
22 | Example | Example | Example | Example | Example |
23 | Example | Example | Example | Example | Example |
24 | Example | Example | Example | Example | Example |
25 | Example | Example | Example | Example | Example |
26 | Example | Example | Example | Example | Example |
27 | Example | Example | Example | Example | Example |
28 | Example | Example | Example | Example | Example |
29 | Example | Example | Example | Example | Example |
30 | - | - | 0v | ||
31 | Example | Example | Example | Example | Example |
32 | Example | Example | Example | Example | Example |
33 | Example | Example | Example | Example | Example |
34 | - | - | 0v | ||
35 | Example | Example | Example | Example | Example |
36 | Example | Example | Example | Example | Example |
37 | Example | Example | Example | Example | Example |
38 | Example | Example | Example | Example | Example |
39 | - | - | 0v | ||
40 | 21 | 29 | GPIO 29 | TX LED and PTT | - |
The BCM numbers in this table correspond to the connector labelling on the Willow Electronics GPIO breakout board. Two of the connections are not broken out and need to be directly connected to the GPIO pins. More details to follow.
