PTT and band switching
Band outputs
| Frequency Mhz | ATV Band | Pin 28 | Pin 35 |
| < 100 MHz | 71 MHz | Lo | Lo |
| 100 - 250 MHz | 146 MHz | Lo | Hi |
| 250 - 950 MHz | 437 MHz | Hi | Lo |
| 950 - 4400 MHz | 23cms | Hi | Hi |
GPIO band decoder
PTT steering
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
David M0YDH shows Ian's design in operation:- G8ADE RELAY SEQUENCER VIDEO and an updated version with extra relay for Portsdown PTT band switching.
Summary of GPIO connections
| Pin No | BCM No | Wiring Pi | RPi Name | Primary Use | Secondary Use |
| 1 | - | - | 3.3v | - | - |
| 2 | - | - | 5v | - | - |
| 3 | 2 | 8 | SDA 1 | - | |
| 4 | - | - | 5v | - | - |
| 5 | 3 | 9 | SCL 1 | - | |
| 6 | - | - | 0v | - | - |
| 7 | 4 | 7 | GPIO 7 | (was DigiThin) | |
| 8 | 14 | 15 | TxD | (was DigiThin) | |
| 9 | - | - | 0v | - | - |
| 10 | 15 | 16 | RxD | (was DigiThin) | |
| 11 | 17 | 0 | GPIO 0 | LCD Display | - |
| 12 | 18 | 1 | GPIO 1 | (was DigiThin) | |
| 13 | 27 | 2 | GPIO 2 | Shutdown LED | |
| 14 | - | - | 0v | - | - |
| 15 | 22 | 3 | GPIO 3 | Shutdown Button | |
| 16 | 23 | 4 | GPIO 4 | LCD Display | - |
| 17 | - | - | 3.3v | - | - |
| 18 | 24 | 5 | GPIO 5 | LCD Display | - |
| 19 | 10 | 12 | MOSI | LCD Display | - |
| 20 | - | - | 0v | - | - |
| 21 | 9 | 13 | MISO | LCD Display | - |
| 22 | 25 | 6 | GPIO 6 | LCD Display | - |
| 23 | 11 | 14 | SCLK | LCD Display | - |
| 24 | 8 | 10 | CE 0 | LCD Display | - |
| 25 | - | - | 0v | - | - |
| 26 | 7 | 11 | CE1 | Touch Sensor | - |
| 27 | 0 | 30 | SDA 0 | ADF4351 LE | - |
| 28 | 1 | 31 | SCL 0 | Band LSB (D0) | - |
| 29 | 5 | 21 | GPIO 21 | ADF4351 CLK | Atten and ADF5355 CLK |
| 30 | - | - | 0v | - | - |
| 31 | 6 | 22 | GPIO 22 | ADF4351 DATA | Atten and ADF5355 DATA |
| 32 | 12 | 26 | GPIO 26 | I output | "Ugly" and RPITX RF output |
| 33 | 13 | 23 | GPIO 23 | Q output | - |
| 34 | - | - | 0v | - | - |
| 35 | 19 | 24 | GPIO 24 | Band MSB (D1) | - |
| 36 | 16 | 27 | GPIO 27 | IQ Filter LSB (D0) | - |
| 37 | 26 | 25 | GPIO 25 | IQ Filter NSB (D1) | - |
| 38 | 20 | 28 | GPIO 28 | IQ Filter MSB (D2) | - |
| 39 | - | - | 0v | - | - |
| 40 | 21 | 29 | GPIO 29 | TX LED and PTT | - |
