PTT and band switching
Band outputs
GPIO band decoder
PTT steering
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
David M0YDH shows Ian's design in operation:- G8ADE RELAY SEQUENCER VIDEO and an updated version with extra relay for Portsdown PTT band switching.
Summary of GPIO connections
Pin No | BCM No | Wiring Pi | RPi Name | Primary Use | Secondary Use | DTX-1 Use |
1 | - | - | 3.3v | - | - | - |
2 | - | - | 5v | - | - | - |
3 | 2 | 8 | SDA 1 | - | - | |
4 | - | - | 5v | - | - | - |
5 | 3 | 9 | SCL 1 | - | - | |
6 | - | - | 0v | - | - | - |
7 | 4 | 7 | GPIO 7 | Keyed Streaming LED Indication | Transverter Select | - |
8 | 14 | 15 | TxD | ADF5355 LE | (was DigiThin) | - |
9 | - | - | 0v | - | - | - |
10 | 15 | 16 | RxD | Attenuator LE | (was DigiThin) | - |
11 | 17 | 0 | GPIO 0 | LCD Display | - | - |
12 | 18 | 1 | GPIO 1 | Keyed Streaming or Keyed TX Switch | - | |
13 | 27 | 2 | GPIO 2 | Shutdown LED | - | |
14 | - | - | 0v | - | - | - |
15 | 22 | 3 | GPIO 3 | Shutdown Button | - | |
16 | 23 | 4 | GPIO 4 | LCD Display | - | - |
17 | - | - | 3.3v | - | - | - |
18 | 24 | 5 | GPIO 5 | LCD Display | - | - |
19 | 10 | 12 | MOSI | LCD Display | - | - |
20 | - | - | 0v | - | - | - |
21 | 9 | 13 | MISO | LCD Display | - | - |
22 | 25 | 6 | GPIO 6 | LCD Display | - | - |
23 | 11 | 14 | SCLK | LCD Display | - | - |
24 | 8 | 10 | CE 0 | LCD Display | - | - |
25 | - | - | 0v | - | - | - |
26 | 7 | 11 | CE1 | Touch Sensor | - | - |
27 | 0 | 30 | SDA 0 | ADF4351 LE | - | - |
28 | 1 | 31 | SCL 0 | Band LSB (D0) | - | - |
29 | 5 | 21 | GPIO 21 | ADF4351 CLK | Atten and ADF5355 CLK | - |
30 | - | - | 0v | - | - | - |
31 | 6 | 22 | GPIO 22 | ADF4351 DATA | Atten and ADF5355 DATA | - |
32 | 12 | 26 | GPIO 26 | I output | "Ugly" and RPITX RF output | - |
33 | 13 | 23 | GPIO 23 | Q output | - | - |
34 | - | - | 0v | - | - | - |
35 | 19 | 24 | GPIO 24 | Band MSB (D1) | - | - |
36 | 16 | 27 | GPIO 27 | IQ Filter LSB (D0) | - | - |
37 | 26 | 25 | GPIO 25 | IQ Filter NSB (D1) | - | - |
38 | 20 | 28 | GPIO 28 | IQ Filter MSB (D2) | - | - |
39 | - | - | 0v | - | - | - |
40 | 21 | 29 | GPIO 29 | TX LED and PTT | - | - |
