Jump to navigation
Jump to search
The latest Software for the Portsdown Transmitter is version 201803061 (the version is the issue date with an added 0-9 serial).
Supported hardware
- Raspberry Pi 3 Model B, with or without a 3.5 inch diagonal Waveshare touchscreen.
- Alternatively, the TX can be controlled over the network from another computer.
- The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator.
- Video input from an EasyCap type USB capture device and from a Pi Camera.
- Support for the C920 Webcam is provided on a best-efforts basis
Outputs
- Control for a DATV Express in DVB-S mode.
- H264 coded video to a DTX-1 through a TS Dock board
- Stream to RTMP server such as batc.tv
Modes
- In DATV Express mode, it will transmit MPEG-2 or H264 picures from the RPi Camera at 125 KS/s - 4 MS/s
- In streaming mode, it will send Pi Camera or EasyCap pictures and sound to the BATC Streamer, or to any other compatible streamer.
- With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 1000 KS/s.
- The ADF4351 VCO or a DATV Express can be controlled as a Signal Generator with the option of QPSK modulation
- The FreqShow Spectrum Viewer can be selected from Menu 2 of the touchscreen.
Future Enhancements
- Display transmitted image on the LCD in all modes
- Add sound channel to H264 video modes
Version history
- Version 201705301 Added a second Touchscreen menu with a shutdown button and enabled Contest mode operation from the touchscreen
- Version 201706301 Adds a number of menu options and the ability to run beta software using a recompiled version of ffmpeg.
- Version 201707120 Adds a PAL composite video output mode from the RPi and corrected the test card sizes.
- Version 201707222 Adds the ability to transmit MPEG-2 and stream from an EasyCap. Video and sound switching is provided.
- Version 201707311 Adds an Info screen on Menu 3, and sound pass-through in "Vid Out" mode.
- Version 201708150 Adds dedicated repeater streaming modes and video still capture.
- Version 201710081 Adds RTL-SDR functionality and keyed transmit.
- Version 201710280 Adds the basic Signal Generator functionality
- Version 201711031 Adds touchscreen calibration
- Version 201711271 Adds an HD Pi Camera MPEG-2 mode and a static MPEG-2 test card.
- Version 201712181 Included a total re-write of the touchscreen touch response function and added 480p MPEG-2 modes
- Version 201801012 Adds the FreqShow Spectrum viewer and basic support for the Element 14 7 inch screen.
- Version 201801061 Adds the ability to use DATV Express or switchable attenuators with the SigGen and tidies RX switching
- Version 201802041 Includes a major menu rewrite and add the facility to use the attenuator and transverters.
- Version 201802202 Minor bugfixes including C920 WebCam functionality
- Version 201803061 H264 HD streaming from C920. Additional HD, widescreen and test card modes
Last updated 15 March 2018. DGC
