8-Band Decoder
Revision as of 18:50, 17 March 2018 by G8GKQ (talk | contribs)
This 8-band decoder is designed to work with the 8-band RF output switch and the "Portsdown 2018" software. It will provide switching signals (either always on, or PTT activated) to 4 power amplifiers and 4 transverters, and it also enables you to set which VCO filter should be switched in for the 4 transverter outputs. PCBs will be available from the BATC Shop.
The schematic is here:File:8 BAND DECODE V2-0 SCH.pdf
The board layout is here:File:8 BAND DECODE V2-0 SS.pdf
A drill template for the board (which has been designed to be a form and fit replacement for the 4-band decoder) is here: File:8 BAND DECODE V2-0 DRILL TEMPLATE.pdf
Wiring
There are 3 logic input lines that run from the GPIO breakout board to J1: The LSB and the MSB come from the 4 band switch connector. The “T” (transverter) line comes from GPIO Pin 7 which you will find labelled as DigiThin 7 on the GPIO breakout. These 3 logic lines also need to be routed to the 8-way RF switch. The current consumption of the board is low, so it could be powered by 3v3 from the Raspberry Pi.
You will need to run wires from J2 to the VCO LO filter, as these should no longer be directly controlled by the RPi.
Setting the VCO Filter for Transverter Bands
to be added
