8-Band Decoder
Revision as of 21:12, 17 March 2018 by G8GKQ (talk | contribs)
This 8-band decoder is designed to work with the 8-band RF output switch and the "Portsdown 2018" software. It will provide switching signals (either always on, or PTT activated) to 4 power amplifiers and 4 transverters, and it also enables you to set which VCO filter should be switched in for the 4 transverter outputs. PCBs will be available from the BATC Shop.
The schematic is here:Media:8 BAND DECODE V2-0 SCH.pdf
The board layout is here:Media:8 BAND DECODE V2-0 SS.pdf
A drill template for the board (which has been designed to be a form and fit replacement for the 4-band decoder) is here: Media:8 BAND DECODE V2-0 DRILL TEMPLATE.pdf
Wiring
There are 3 logic input lines that run from the GPIO breakout board to J1: The LSB and the MSB come from the 4 band switch connector. The “T” (transverter) line comes from GPIO Pin 7 which you will find labelled as DigiThin 7 on the GPIO breakout. These 3 logic lines also need to be routed to the 8-way RF switch. The current consumption of the board is low, so it could be powered by 3v3 from the Raspberry Pi.
You will need to run wires from J2 to the VCO LO filter, as these should no longer be directly controlled by the RPi.
Setting the VCO Filter for Transverter Bands
One of the resons for using a PIC on this PCB is to allow the LO Filter to be set correctly for the Transverter bands. The 8 DIP switches (or solder bridges if the switch is not fitted) need programming depending on the IF frequency used for each transverter.
The board is marked with T1, T2, T3 and T4 to designate the pair of switches for each transverter; it is also marked with LSB (nearest J2) and MSB (nearest J3) Use the following table to determine the settings for each transverter.
IF Frequency MHz IF Band LSB MSB
< 100 MHz 71 MHz On On
100 - 250 MHz 146 MHz Off On
250 - 950 MHz 437 MHz On Off
950 - 4400 MHz 23cms Off Off
"on" is equivalent to bridged with solder.
