Portsdown transmitter FAQ
- How do I prevent regular clicks/thumps on Streamed audio?
Check the following: 1. A valid video signal must be present at the input to the EasyCap before you turn the streaming on. 2. The supply voltage, measured on the GPIO pins, should be between 5.0 and 5.1 volts during streaming. 3. The EasyCap should be plugged directly into the RPi or connected by a short, good quality, USB lead.
- Why do I get occasional dropouts of the received or streamed picture at 16:9 or 720p?
The Raspberry Pi 3 is working at its processing limit at these higher resolutions and occasionally runs out of resources. 16:9 is particularly bad because it is generated by down-scaling 720p, or stretching SD.
- Can I use the new Raspberry Pi 3+?
The Portsdown team are working on a new build that will run on the Raspberry Pi 3+. The current build needs some modifications to work on the new RPi 3+. So: not yet.
- How do I turn the transmitter off in Touchscreen mode?
- What do I need to receive a Portsdown transmitter?
When a Portsdown transmitter is fitted with a filter / modulator card and running in normal bandwidth modes (above 1 Msymbol/sec) you will be able receive it on any Free to Air (or FreeSat but not Sky or Freeview) satellite Set top box - if you have a High Definition STB you will be able to receive MPEG-2 and MPEG-4.
However, when it is running in RB-TV modes OR in Ugly mode without the Filter Modulator card, you can only receive it using the MiniTiouner USB receiver. This is a BATC supported project with some home construction needed - the hardware components are available from the BATC shop and the software is a free download from F6DZP see here for more details.
- Can I use another touchscreen LCD?
The Portsdown project only supports the Waveshare screen - that doesn't mean to say others won't work but we can't help you if it doesn't. The Element 14 7 inch touchscreen is the only recommended alternative. HDMI-connected touchscreens are not suitable.
- Can I use a Raspberry Pi 2?
- Who are the Portsdown team?
- Do I need to know about Linux or other clever computer stuff to get Portsdown running?
- Does Portsdown mean BATC will stop selling the DTX1 like they did DATVexpress?
NO - The DTX1 is designed for those who do not want to "build their own" and will still be available in the BATC shop and supported by Antennair through the DTX1 support website. DATVexpress is no longer in production - the reason we stopped selling it in the BATC shop is because the DATV Express team wanted to offer it directly to end users.
- Is Portsdown MPEG-2 or MPEG-4?
Both - The RPi hardware encoder runs MPEG-4 and the Portsdown software has an MPEG-2 encoder both of which are used in the Portsdown transmitter.
- Why can't I download or update the software?
- When I type my password, the cursor does not move. Is this right?
- How do I get out of touch screen back in to console mode?
- Connect the RPi to the same network as your PC, and either check on the touchscreen "info" page (on Menu 3) or use the IP Scanner to find the IP address of your RPi.
- Open Putty and enter the IP address of your RPi and open a connection. At the logon prompt enter the default username of pi and the password given to you with the card.
The console menu should start automatically and the touchscreen will display the BATC logo.
Note, if the console menu does not appear and you end up at the Linux Command Line, you can get back to the Main Console Menu by typing:
- When I Log-on or start the Console Menu, it goes Straight to the Exit Screen. How do I recover?
If you accidentally enter a space character when entering the frequency or symbol rate, the Menu software fails and tries to exit. You can recover by typing the command:
cp -f /home/pi/rpidatv/scripts/configs/portsdown_config.txt.factory /home/pi/rpidatv/scripts/portsdown_config.txt
at the Linux command line, and then restarting the console menu with the command:
- How Can I update my Portsdown Software?
As long as you have an internet connection, you can update your Portsdown Software to the latest version from the Console Menu. Full instructions are here: Updating your Portsdown Software
- Where can I get a diagram of all the RPi GPIO pins?
PTT and band switching#Summary_of_GPIO_connections
- The lock LED on the AD4351 board does not come on
The lock light only comes on when in Portsdown/IQ mode and you are on Transmit
