IARU ATV contest
The 2018 event is on 10/11 June - the contest starts at 1 pm UK time on the Saturday and runs through until 7 pm on the Sunday, so there is plenty of time to get on the air.
This is an international contest and ATV operators in all countries in IARU region 1 enter and a table of results is produced showing a lkeague table of entries based on bands used and number of entries from each country.
Who can enter?
The rules allow for “roving” stations, so there is no reason why you should not operate from home on one day, and go out portable on another, or even use multiple portable sites. Just remember to use new 4-digit codes from each location (and to ask for new codes from any station that you have worked before).
The numbers can be scribbled on a piece of paper or computer generated. The Portsdown system automatically generates a different set of numbers for each band - see here for more details.
Signal reports
Start the serial number from 001 for each band; if you are unsuccessful in receiving pictures, you can send back a report such as P0003. This ensures that your attempt at a contact appears in the log.
Dxspot.tv https://www.dxspot.tv/ was set up to co-ordinate ATV contacts and have a real time chat room where you can message other ATV operators directly - we suggest you register for an account before the contest.
There is also a low bandwidth chat room only set up for mobile use here:
Time of contest
The contest rules refer to times in UTC: this is Universal Coordinated Time (the abbreviation comes from the French translation which is internationally accepted). Many of us will know this as Greenwich Mean Time (GMT), which is the clock time in the UK during the winter, but one hour behind in the Summer when we use British Summer Time (BST). This is why the International Contest starts at 1pm and finishes at 7pm for us.
Submitting an entry
To submit an entry....
More information
The latest Rules for the International ATV Contest can be downloaded here (.pdf).
The Contest Manager can be contacted on contests@batc.tv
