Configuring your channel
  • To configure your streaming channel you will need to log in as a member and then go to your account dashboard - see this page for more details on your account dashboard - scroll down on the page to Streaming details.
Chat nick name
Stream Title
Stream output URL
Note - the full URL is made up of the https address above the grey box PLUS the text in the grey box (which is the stream name) without any spaces between the 2.
Stream input URL
Note - the full URL is "rtmp://rtmp.batc.org.uk/live/xxxxx-yyyyy" where xxxx is the stream name listed in the first grey box and yyyy is the key listed in the second grey box. The stream name and key are separated by a hyphen.
Streaming from the Portsdown
Using Adobe Media encoder
For Adobe media encoder put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to... and the text "g8gkq-abcxyz" in the grey box in to...
Using Vmix
For Vmix put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to the "URL" field and the text "g8gkq-abcxyz" in to "stream Name or key" box.
Using OBS
Stream type
Stream options
Streaming type
The Streaming Type can be set to Flash or HTML5. Flash has the advantage of minimal delay, but is not compatible with the stock browser on some devices. (Flash will need specifically enabling in Chrome, Firefox and Edge browsers). HTML5 works with all modern browsers, including iphones and ipads but is subject to a 10 - 20 second delay.
=tream description
The stream description is the area below the video player and text chat windows on your channel page. This area can be used by you to describe your channel and give more details of your group or repeater.
It is a Free text area and can include HTML - we recommend you use an external HTML editor such as https://html-online.com/editor/ to get the correct look and then paste the code in to the space.
Please note any embedded content such as maps and time clocks etc from other sites need to use an SSL connection and have an https:// address.
