The latest Software for the Portsdown Transmitter is version 201807090 (the version is the issue date with an added 0-9 serial).
- Portsdown 2018 Stretch, which should be used for all new builds, and supports both the Raspberry Pi 3 B and the Pi 3 B+ https://github.com/BritishAmateurTelevisionClub/portsdown
- Portsdown 2018 Jessie, which is the software that has been developed since the beginning of the project and will be maintained with similar capabilities to the "Stretch" build for as long as possible. This can be found at https://github.com/BritishAmateurTelevisionClub/rpidatv.
Supported hardware
- Raspberry Pi 3 Model B, with or without a 3.5 inch diagonal Waveshare touchscreen.
- Raspberry Pi 3 Model B+, (Portsdown 2018 Stretch software ONLY)
- Alternatively, the TX can be controlled over the network from another computer.
- The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz or other Reference Oscillator.
- Video input from an EasyCap type USB capture device, Pi Camera or selected webcams.
- Support for the C170, C270, C525, C910 and C920 Webcams is provided on a best-efforts basis
Outputs
- Control for a DATV Express in DVB-S mode.
- H264 coded video to a DTX-1 through a TS Dock board
- Transport Stream over UDP
- Stream to RTMP server such as https://batc.org.uk/live
Modes
- In DATV Express mode, it will transmit MPEG-2 or H264 picures from the RPi Camera at 125 KS/s - 4 MS/s
- In streaming mode, it will send Pi Camera or EasyCap pictures and sound to the BATC Streamer, or to any other compatible streamer.
- In "Stream Display" mode, the Portsdown will display any selected stream from the BATC server and provide audio on the 3.5mm jack.
- With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 1000 KS/s.
- The ADF4351 VCO or a DATV Express can be controlled as a Signal Generator with the option of QPSK modulation
- The FreqShow Spectrum Viewer can be selected from Menu 2 of the touchscreen.
Future Enhancements
- Display transmitted image on the LCD in all modes
- Add sound channel to H264 video modes
Version history
- Version 201705301 Added a second Touchscreen menu with a shutdown button and enabled Contest mode operation from the touchscreen
- Version 201706301 Adds a number of menu options and the ability to run beta software using a recompiled version of ffmpeg.
- Version 201707120 Adds a PAL composite video output mode from the RPi and corrected the test card sizes.
- Version 201707222 Adds the ability to transmit MPEG-2 and stream from an EasyCap. Video and sound switching is provided.
- Version 201707311 Adds an Info screen on Menu 3, and sound pass-through in "Vid Out" mode.
- Version 201708150 Adds dedicated repeater streaming modes and video still capture.
- Version 201710081 Adds RTL-SDR functionality and keyed transmit.
- Version 201710280 Adds the basic Signal Generator functionality
- Version 201711031 Adds touchscreen calibration
- Version 201711271 Adds an HD Pi Camera MPEG-2 mode and a static MPEG-2 test card.
- Version 201712181 Included a total re-write of the touchscreen touch response function and added 480p MPEG-2 modes
- Version 201801012 Adds the FreqShow Spectrum viewer and basic support for the Element 14 7 inch screen.
- Version 201801061 Adds the ability to use DATV Express or switchable attenuators with the SigGen and tidies RX switching
- Version 201802041 Includes a major menu rewrite and add the facility to use the attenuator and transverters.
- Version 201802202 Minor bugfixes including C920 WebCam functionality
- Version 201803061 H264 HD streaming from C920. Additional HD, widescreen and test card modes
- Version 201803181 Revised C525 webcam reset logic. Corrected audio switching bug. Added C910 Webcam Support
- Version 201804020 Added functionality (including software update) from the touchscreen.
- Version 201804061 Adds FreqShow and VideoView functionality and other minor improvements for the Element 14 7 inch Screen
- Version 201804251 Adds an RTL-FM Receiver on Menu 2 and improves visibility of the DATV Express Firmware load
- Version 201805150 Adds a locator bearing calculator and improves the Composite video output facility.
- Version 201807041 Adds an independent LeanDVB Receiver Menu, and a Receive LO Generation Capability.
- Version 201807091 Introduces performance improvements for the LeanDVB receiver
- Version 201807151 Adds the ability to display any BATC Stream.
Last updated 15 July 2018. DGC
