H264 Encoding with Audio
Software version 201810270 (not yet released) introduces the capability to add audio to H264 encoded video. This is achieved using a new version of avc2ts (written by F5OEO). This version has some limitations, but achieves much better picture quality from the Pi Camera at low SRs than the previous version.
Audio
The audio is encoded using an AAC encoder at 20 Kbit/second takes up very little of the available bandwidth. In some modes there is an occasional (once every 10 minutes or so) 5 second burst of noise on the audio. The cause of this is not yet known.
Pi Camera Mode
This mode works well from 250 KS 7/8 FEC up to 4 MS. For lower symbol rates, the Audio should be switched off, which will switch in the older avc2ts encoder without audio.
Note that on the Waveshare 3.5 inch screen, the viewfinder does not fill the screen. This is intended behaviour.
Composite Video Input Mode
Animated Test card (TCAnim) Mode
The animated test card mode now transmits a smooth (not jerky) picture with bouncing balls. However, this is not displayed on the touchscreen (a static test card is displayed). It is not possible to encode H264 video with audio whilst also refreshing the picture on the Waveshare 3.5 inch display. If audio is switched off, the old H264 encoder is used and the animated test card is displayed.
There are some video drop-outs if TCAnim with audio is used above 2MS 7/8 FEC, or below 250 KS 7/8 FEC. At the lower SRs it is best to turn off the audio, which switches to the old H264 encoder.
Static Test Card and Contest Card
Webcams
Initial testing with a Logitech C190 webcam has given poor results, both for video (poor motion handling) and audio (intermittent). Other webcams have not yet been tested.
