Talk:RBTVMOD
Here is the Bill of Materials to build the RBTVMOD project File:RBTVMOD V21.xls
The circuit diagram is in two parts this is the first part File:RBTVMOD V21 Sht 1.pdf
And this is the 2nd part File:RBTVMOD V21 Sht 2.pdf
Silkscreen is here File:RBTVMOD V22 Silk screen.png
For those who want to make there own PCBs, the artwork is here File:RBTVMOD V22 copper.pdf There are some fairly small traces close together
V21 OFFSET BALANCE TEST POINTS
One of the test points was incorrect on the PCB (The Q-) see File:V21 OFFSET BALANCE TEST POINTS.png
A printer friendly version here File:V21 OFFSET BALANCE TEST POINTS pf.png
Parts ordering from BOM
Making up kits of parts for projects is time consuming and expensive, an alternative is to supply a BOM (Bill Of Materials) that can be uploaded to a supplier, they will effectively make up the kit of parts for you! and even print the part No on the packets ( such as R1,R2 etc.)
The word file File:Using the DigiKey BOM Manager.doc shows how to do this for RBTVMOD when ordering from DigiKey.
