PTT and band switching
Band outputs
Frequency Mhz ATV Band Pin 28 Pin 35
< 100 MHz 71 MHz Lo Lo
100 - 250 MHz 146 MHz Lo Hi
250 - 950 MHz 437 MHz Hi Lo
950 - 4400 MHz 23cms Hi Hi
GPIO band decoder
File:DECODE 4 Band Decode BOM 4bbom.xlsx
PTT steering
These band outputs can then used to "steer" the PTT line to the correct Power Amplifier using this simple relay and diode circuit - no PCB needed :-)
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
David M0YDH shows Ian's design in operation:- G8ADE RELAY SEQUENCER VIDEO and an updated version with extra relay for Portsdown PTT band switching.. If you prefer an elegant kit solution then you could try the TROPIC sequencer from Shortwave radio.This is listed at £11.50 but price is available on application. W6PQL and W1GHZ have sequencer designs.
Summary of GPIO connections
Pin No BCM No Wiring Pi RPi Name Primary Use Secondary Use DTX-1 Use
1 - - 3.3v - - EXT-DVLM
2 - - 5v - - -
3 2 8 SDA 1 - EXT-SD0
4 - - 5v - - -
5 3 9 SCL 1 - EXT-SD1
6 - - 0v - - -
7 4 7 GPIO 7 Keyed Streaming LED Indication Transverter Select
or incoming stream active
EXT-SD2
8 14 15 TxD ADF5355 LE Elcom LE EXT-SD3
9 - - 0v - - -
10 15 16 RxD Attenuator LE - EXT-SD4
11 17 0 GPIO 0 LCD Display - EXT-SD5
12 18 1 GPIO 1 Keyed Streaming or Keyed TX Switch EXT-SD6
13 27 2 GPIO 2 Shutdown LED EXT-SD7
14 - - 0v - - -
15 22 3 GPIO 3 Shutdown Button EXT_TSCLK
16 23 4 GPIO 4 LCD Display - -
17 - - 3.3v - - -
18 24 5 GPIO 5 LCD Display - EXT-PSYM
19 10 12 MOSI LCD Display - -
20 - - 0v - - -
21 9 13 MISO LCD Display - -
22 25 6 GPIO 6 LCD Display - -
23 11 14 SCLK LCD Display - -
24 8 10 CE 0 LCD Display - -
25 - - 0v - - -
26 7 11 CE1 Touch Sensor - -
27 0 30 SDA 0 ADF4351 LE - -
28 1 31 SCL 0 Band LSB (D0) - -
29 5 21 GPIO 21 ADF4351 CLK Atten and ADF5355 CLK -
30 - - 0v - - -
31 6 22 GPIO 22 ADF4351 DATA Atten and ADF5355 DATA -
32 12 26 GPIO 26 I output "Ugly" and RPITX RF output -
33 13 23 GPIO 23 Q output - -
34 - - 0v - - -
35 19 24 GPIO 24 Band MSB (D1) - -
36 16 27 GPIO 27 IQ Filter LSB (D0) - -
37 26 25 GPIO 25 IQ Filter NSB (D1) - -
38 20 28 GPIO 28 IQ Filter MSB (D2) - -
39 - - 0v - - -
40 21 29 GPIO 29 TX LED and PTT Drive - -
