PTT and band switching
Band outputs
GPIO band decoder
File:DECODE 4 Band Decode BOM 4bbom.doc
PTT steering
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
David M0YDH shows Ian's design in operation:- G8ADE RELAY SEQUENCER VIDEO and an updated version with extra relay for Portsdown PTT band switching.. If you prefer an elegant kit solution then you could try the TROPIC sequencer from Shortwave radio.This is listed at £11.50 but price is available on application. W6PQL and W1GHZ have sequencer designs.
Summary of GPIO connections
Pin No | BCM No | Wiring Pi | RPi Name | Primary Use | Secondary Use | DTX-1 Use |
1 | - | - | 3.3v | - | - | EXT-DVLM |
2 | - | - | 5v | - | - | - |
3 | 2 | 8 | SDA 1 | - | EXT-SD0 | |
4 | - | - | 5v | - | - | - |
5 | 3 | 9 | SCL 1 | - | EXT-SD1 | |
6 | - | - | 0v | - | - | - |
7 | 4 | 7 | GPIO 7 | Keyed Streaming LED Indication | Transverter Select or incoming stream active |
EXT-SD2 |
8 | 14 | 15 | TxD | ADF5355 LE | Elcom LE | EXT-SD3 |
9 | - | - | 0v | - | - | - |
10 | 15 | 16 | RxD | Attenuator LE | - | EXT-SD4 |
11 | 17 | 0 | GPIO 0 | LCD Display | - | EXT-SD5 |
12 | 18 | 1 | GPIO 1 | Keyed Streaming or Keyed TX Switch | EXT-SD6 | |
13 | 27 | 2 | GPIO 2 | Shutdown LED | EXT-SD7 | |
14 | - | - | 0v | - | - | - |
15 | 22 | 3 | GPIO 3 | Shutdown Button | EXT_TSCLK | |
16 | 23 | 4 | GPIO 4 | LCD Display | - | - |
17 | - | - | 3.3v | - | - | - |
18 | 24 | 5 | GPIO 5 | LCD Display | - | EXT-PSYM |
19 | 10 | 12 | MOSI | LCD Display | - | - |
20 | - | - | 0v | - | - | - |
21 | 9 | 13 | MISO | LCD Display | - | - |
22 | 25 | 6 | GPIO 6 | LCD Display | - | - |
23 | 11 | 14 | SCLK | LCD Display | - | - |
24 | 8 | 10 | CE 0 | LCD Display | - | - |
25 | - | - | 0v | - | - | - |
26 | 7 | 11 | CE1 | Touch Sensor | - | - |
27 | 0 | 30 | SDA 0 | ADF4351 LE | - | - |
28 | 1 | 31 | SCL 0 | Band LSB (D0) | - | - |
29 | 5 | 21 | GPIO 21 | ADF4351 CLK | Atten and ADF5355 CLK | - |
30 | - | - | 0v | - | - | - |
31 | 6 | 22 | GPIO 22 | ADF4351 DATA | Atten and ADF5355 DATA | - |
32 | 12 | 26 | GPIO 26 | I output | "Ugly" and RPITX RF output | - |
33 | 13 | 23 | GPIO 23 | Q output | - | - |
34 | - | - | 0v | - | - | - |
35 | 19 | 24 | GPIO 24 | Band MSB (D1) | - | - |
36 | 16 | 27 | GPIO 27 | IQ Filter LSB (D0) | - | - |
37 | 26 | 25 | GPIO 25 | IQ Filter NSB (D1) | - | - |
38 | 20 | 28 | GPIO 28 | IQ Filter MSB (D2) | - | - |
39 | - | - | 0v | - | - | - |
40 | 21 | 29 | GPIO 29 | TX LED and PTT Drive | - | - |
