Initial setup 2019
Jump to navigation
Jump to search
Important note - the Portsdown transmitter has been designed to "work out of the box". Most things can be set-up from the touchscreen. A few more advanced functions require you to connect to your Portsdown over a network from a PC.
Note that if you have a 7 inch Touchscreen, you should start at "Set-up using a PC"
- Do not connect a mouse, keyboard or monitor to the Raspberry Pi
- Do not load any device drivers including the Waveshare screen drivers
Set Up through the 3.5 inch Touchscreen
Once you have a RPi and an SD card with the Portsdown firmware installed - either from the BATC shop or by following the instructions in this section of the user guide connect the Waveshare 3.5 inch touchscreen (being careful to align the pins correctly)
