UK ATV repeaters
Revision as of 12:22, 2 February 2019 by M0DHP (talk | contribs) (→‎GB3GV)
There are over 30 active ATV repeaters in the UK and the current status and operating frequencies can be found on the RSGB ETCC TV list
You can watch most UK ATV repeaters on the BATC video streaming service.
To add your repeater to this page, simply add a description, preferably in alphabetic order.
GB3AT
GB3AT is the new 10 GHz TV repeater project on the Isle of Wight at IO90IR.
Currently testing as G8MBU's personal beacon
Output (analogue): 10235 MHz FM ATV
GB3ET
GB3ET is the proposed new 23cms ATV repeater at Edgehill approximately 6 Miles NW of Banbury.
GB3FT
GB3FT is the new 23cms TV repeater for Blackpool and surrounding area.
GB3GV
GB3GV is a 23cm ATV repeater located in Markfield Leicestershire and operated by the Leicestershire Repeater Group
Output (digital) is 1318.5Mhz (4M/S 1/2FEC)
Input (digital and analogue) 1249Mhz (4M/S 1/2FEC for digital)
Input (digital only) 437Mhz (2M/S 1/2 FEC)
Narrowband RX is planned on 146.5Mhz (333K/S 7/8FEC)
Talkback on 144.750, if busy we may switch to 144.525
Visit https://www.leicestershirerepeatergroup.org.uk/repeaters/gb3gv for more information
GB3HV
GB3HV is the 3.4 GHz output repeater located near Farnham in Surrey. For more details visit our website.
GB3JT
GB3JT is the new 23cms TV repeater for Hastings and surrounding area.
Output (digital): 1318 MHz DVB-S, 4 MSymbols, 1/2 FEC. (24/7 TX Video Test Card during Testing)
Input (analogue): 1249 MHz (Under Development. Future RX)
Input (digital): 1249 MHz DVB-S, 4 Msymbols, auto FEC, PIDs auto detected (Under Development. Future RX)
Input (digital): 437 MHz DVB-S, 2 Msymbols, auto FEC, PIDs auto detected (Under Development. Future RX with added cavities due to other co-located 70cm repeaters)
The repeater antenna is an Angled Slot, mounted on top of the GB3HE four stack, which is on top of the main mast located ~ 500 feet ASL on the Ark Helenswood in Hastings TN34 2AF.
Talkback audio channel is currently taken directly from GB3HE, with future 2M RX to be added. DATV/ATV audio will be auto switching on second channel.
For more details please visit RILGES Repeater Group.
GB3KM
Located in Kirk Merrington, County Durham, IO94EQ - 200mAsl.
Analogue Inputs: 1.280GHz, 2.328GHz, 5.665GHz (6.5MHz Audio), 10.315GHz.
Digital Input: 1.280GHz - 4Ms, MPEG-2 FEC:Auto PMT:4095 V:256 A:257.
Primary Digital Output: 3.406GHz 2Ms, MPEG-2 FEC:7/8 PMT:4095 V:256 A:257.
Secondary Analogue Outputs: 2.440GHz, 10.065GHz.
Live video is streamed from 9cm output by M0DTS - 28km from the repeater using an indoor antenna.
144.750 audio currently off.
Operating hours 11:30-23:30.
GB3NV
GB3NV is the 9cm TV repeater for central Norwich.
Output (digital): 3406 MHz sr2000 ks/s
Input (digital): 437 MHz sr2000 ks/s PIDs auto detected by rx
Full details here: https://forum.batc.org.uk/viewtopic.php?f=95&t=4726&p=11191
GB3TM
GB3TM is the 23cm TV repeater for the Isle of Anglesey and North Wales coastal areas.
Output (digital): 1316 MHz sr4700 ks/s
For more details please visit Arfon Repeater Group.
GB3TN
GB3TN is the 23cm TV repeater located in central Norfolk.
Output (analogue): 1316 MHz
GB3UD
GB3UD is an ATV repeater situated at Mow Cop, Staffordshire IO83VC.
Output Digital @ 1318.5 Mhz @4MS/s VID 162 - PMT 32 - AUDIO 88 - FEC 1/2.
Input (Analogue and Digital) 1249 MHz.
NOTE OUTPUT IS DIGITAL ONLY REGARDLESS OF ANALOGUE OR DIGITAL INPUT USED.
GB3UT
Bath University Analogue Input frequency = 1249.0MHz Analogue Output frequency = 1311.5MHz Digital input also available on 1249.00MHz @ 4MS/s with a fec of 3/4
GB3YT
GB3YT is the 23cm TV Repeater located in Mirfield, West Yorkshire.
23cm Digital input frequency = 1276MHz (QPSK): SR = 4Ms/s : FEC = 1,2
70cm Digital input frequency = 437Mhz : SR = 2Ms/s : FEC = 1,2
Analogue input frequency = 1276MHz (FM) : Audio 6MHz
Digital only output = 1316MHz : SR = 4Ms/s
Talkback on 2m = 144.750MHz (CTCSS 118.8Hz)
During QSO, Main audio on Left channel, 2m talkback on Right audio channel.
Full details and latest news at GB3YT Website
GB3ZZ
Filton, north Bristol. Transmits digital ATV on 1316MHz and accepts DATV or FM input on 1249MHz and DATV input on 437MHz.
