Jetson Nano
Revision as of 12:05, 10 June 2019 by M0DNY (talk | contribs) (→G8GKQ's Installation Procedure: Add note about unattended-upgr.)
This page is a starting point for resources for using the Jetson Nano to drive a LimeSDR to transmit DATV.
Download the Jetson Nano disk image to a PC and unzip it. Use Win32 Disk Imager or Etcher to write it to your SD Card.
Fit the jumper link to the Nano PCB to select the use of the 2.1mm power socket, insert the SD Card, connect the monitor, keyboard and mouse. Connect the Nano to your home network and then connect the power and turn it on. Go through the NVIDIA start up routine so that you have a working Nano connected to your network. I used the username "nano" and the password "jetson". These are weak and obvious and should only be used on private networks, but make scripting easy.
Note that the process may seem to freeze on "waiting for unattended-upgr to exit" for around 30 minutes, this is expected, the system is automatically updating software in the background.
sudo apt-get update
sudo apt-get -y dist-upgrade
sudo apt-get -y install git htop nano vlc
Installing DATV Software
git clone https://github.com/F5OEO/dvbsdr
cd dvbsdr
./install.sh
Current Limitations
The only input devices that work with this script are the LKV373A, and the Pi Cam when connected to the Jetson board. The PiCam will not work without a USB microphobe dongle connected to the Jetson board- without this it never transmits a picture.
The C920, although referenced in some of the code, does not work with this configuration.
This is probably the most difficult part of the installation. More details to follow, but I upgraded the firmware (not encoder) to 20160427 using the instructions here: https://www.yodeck.com/docs/display/YO/Creating+a+Video-Wall+with+Yodeck#CreatingaVideo-WallwithYodeck-J.ConfiguringtheLKV373ASenderunit . I also set the unit to factory defaults, but did not change any other settings.
The address for the stream is almost always udp://@239.255.42.42:5004 (you can paste this into VLC on a PC and watch the stream). Note that you cannot paste it into VLC on the Jetson Nano - for some reason it does not work.
Modifying the Scripts
To transmit using the Nano, you will need to plug a LimeSDR Mini into it. You will also need to modify the script ~/dvbsdr/scripts/jetson_nano.sh. The working script is here:
#!/bin/bash
# ************** ENCODE AND MODULATE FOR JETSON NANO ******************
# ************** (c)F5OEO April 2019                 ******************
CALL=G8GKQ
# ------- MODULATION PARAMETERS --------
# 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10 for DVB-S2 QPSK.
# 3/5,2/3,3/4,5/6,8/9,9/10 for DVB-S2 8PSK
source ./include/modulateparam.sh
FREQ=2409.25
SYMBOLRATE=500
FECNUM=1
FECDEN=2
#DVBS,DVBS2
MODE=DVBS2
#QPSK,8PSK,16APSK,32APSK
CONSTELLATION=QPSK
GAIN=0.8
# $LONG_FRAME,$SHORT_FRAME
TYPE_FRAME=$LONG_FRAME
# $WITH_PILOTS,WITHOUT_PILOTS
PILOTS=$WITHOUT_PILOTS
# Upsample 1,2 or 4 : 4 delivers the best quality but should not be up to 500KS
UPSAMPLE=2
# ------- ENCODER PARAMETERS --------
VIDEO_RESX=1280
# 16:9 or 4:3
RATIO=16:9
case "$RATIO" in
"16:9")
let VIDEO_RESY=VIDEO_RESX*9/16 ;;
"4:3")
let VIDEO_RESY=VIDEO_RESX*3/4 ;;
esac
#Uncomment if don't want to use ratio calculation
#VIDEO_RESY=1080
#Only 25 is working well with audio
VIDEO_FPS=25
#Gop Size 1..400 (in frame)
VIDEO_GOP=100
PCR_PTS=200000
#VIDEO INPUT
#Could be  VIDEOSOURCE_PICAMERA, VIDEOSOURCE_USB_CAM , VIDEOSOURCE_IP
VIDEOSOURCE=VIDEOSOURCE_IP
#VIDEOSOURCE=VIDEOSOURCE_PICAMERA
VIDEOSOURCE_IP_ADRESS=239.255.42.42
VIDEOSOURCE_IP_PORT=5004
# H264 or H265
CODEC=H265
#AUDIO INPUT
# NO_AUDIO,USB_AUDIO,FILE_WAV,BEEP
AUDIOSOURCE=USB_AUDIO
AUDIO_BITRATE=20000
# Bitrate
source ./include/getbitrate.sh
let TS_AUDIO_BITRATE=AUDIO_BITRATE*14/10
let VIDEOBITRATE=(BITRATE_TS-12000-TS_AUDIO_BITRATE)*650/1000
let VIDEOPEAKBITRATE=VIDEOBITRATE*110/100
#OUTPUT TYPE LIME or IP
OUTPUT=LIME
OUTPUT_NETWORK="230.0.0.10:10000"
# Launch processes
echo
echo VideoBitrate = $VIDEOBITRATE
echo VideoPeakBitrate = $VIDEOPEAKBITRATE
case "$OUTPUT" in
"LIME")
source ./include/nanoencode.sh | source ./include/limerf.sh
"IP")
esac
Transmitting
cd ~/dvbsdr/scripts
./jetson_nano.sh
Update - Control from Portsdown Touchscreen
Version 201905070 of the Portsdown Software (currently only available as a Development Release) introduces Control of a Jetson Nano set up as above from the Portsdown touchscreen in H265 HDMI mode ONLY.
To set this up, load the development release, and then edit the file
/home/pi/rpidatv/scripts/jetson_config.txt
with your settings:
jetsonip=192.168.2.113
jetsonuser=nano
jetsonpw=jetson
jetsonrootpw=jetson
lkvudp=239.255.42.42
lkvport=5004
tsoutip=192.168.2.177
tsoutport=10000
You will probably only need to change the 4 jetson lines. After you have done this, use the touchscreen to select:
  • Output to: Jetson Lime
  • Encoder: H265
  • Source: HDMI
Then you can select other settings as required. Testing has only been conducted over a narrow range of SRs and FECs. 500KS, FEC 1/2 is a good starting point.
The Jetson settings will be configuarable from the Portsdown touchscreen in a future release.
