Jetson Nano
This page is a starting point for resources for using the Jetson Nano to drive a LimeSDR to transmit DATV.
Download the Jetson Nano disk image to a PC and unzip it. Use Win32 Disk Imager or Etcher to write it to your SD Card.
Fit the jumper link to the Nano PCB to select the use of the 2.1mm power socket, insert the SD Card, connect the monitor, keyboard and mouse. Connect the Nano to your home network and then connect the power and turn it on. Go through the NVIDIA start up routine so that you have a working Nano connected to your network. I used the username "nano" and the password "jetson". These are weak and obvious and should only be used on private networks, but make scripting easy.
Note that the process may seem to freeze on "waiting for unattended-upgr to exit" for around 30 minutes, this is expected, the system is automatically updating software in the background.
sudo apt-get update sudo apt-get -y dist-upgrade sudo apt-get -y install git htop nano vlc v4l-utils
Installing DATV Software
git clone https://github.com/F5OEO/dvbsdr cd dvbsdr ./install.sh
Current Limitations
The only input devices that work with this script are the LKV373A, and the Pi Cam when connected to the Jetson board. The PiCam will not work without a USB microphone dongle connected to the Jetson board - without this it never transmits a picture.
The C920, although referenced in some of the code, does not work with this configuration.
This is probably the most difficult part of the installation. More details to follow, but I upgraded the firmware (not encoder) to 20160427 using the instructions here: https://www.yodeck.com/docs/display/YO/Creating+a+Video-Wall+with+Yodeck#CreatingaVideo-WallwithYodeck-J.ConfiguringtheLKV373ASenderunit . I also set the unit to factory defaults, but did not change any other settings.
After the firmware upgrade, the username and password for the LKV373A is admin/123456.
If you have issues with the firmware upgrade, recovery might be possible using the IPV Tools application found here: https://drive.google.com/drive/u/0/folders/0B3mWuDyxrXyKSTZZZlRESlpBZmM.
The address for the stream is almost always udp://@239.255.42.42:5004 (you can paste this into VLC on a PC and watch the stream). Note that you cannot view the stream using VLC on the Jetson Nano - for some reason it does not work.
Modifying the Scripts
To transmit using the Nano, you will need to plug a LimeSDR Mini into it. You will also need to modify the script ~/dvbsdr/scripts/jetson_nano.sh. The working script is here:
#!/bin/bash # ********************************************************************* # ************** ENCODE AND MODULATE FOR JETSON NANO ****************** # ************** (c)F5OEO April 2019 ****************** # ********************************************************************* CALL=G8GKQ # ------- MODULATION PARAMETERS -------- # 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10 for DVB-S2 QPSK. # 3/5,2/3,3/4,5/6,8/9,9/10 for DVB-S2 8PSK source ./include/modulateparam.sh FREQ=2409.25 SYMBOLRATE=500 FECNUM=1 FECDEN=2 #DVBS,DVBS2 MODE=DVBS2 #QPSK,8PSK,16APSK,32APSK CONSTELLATION=QPSK GAIN=0.8 # $LONG_FRAME,$SHORT_FRAME TYPE_FRAME=$LONG_FRAME # $WITH_PILOTS,WITHOUT_PILOTS PILOTS=$WITHOUT_PILOTS # Upsample 1,2 or 4 : 4 delivers the best quality but should not be up to 500KS UPSAMPLE=2 # ------- ENCODER PARAMETERS -------- VIDEO_RESX=1280 # 16:9 or 4:3 RATIO=16:9 case "$RATIO" in "16:9") let VIDEO_RESY=VIDEO_RESX*9/16 ;; "4:3") let VIDEO_RESY=VIDEO_RESX*3/4 ;; esac #Uncomment if don't want to use ratio calculation #VIDEO_RESY=1080 #Only 25 is working well with audio VIDEO_FPS=25 #Gop Size 1..400 (in frame) VIDEO_GOP=100 PCR_PTS=200000 #VIDEO INPUT #Could be VIDEOSOURCE_PICAMERA, VIDEOSOURCE_USB_CAM , VIDEOSOURCE_IP VIDEOSOURCE=VIDEOSOURCE_IP #VIDEOSOURCE=VIDEOSOURCE_PICAMERA VIDEOSOURCE_IP_ADRESS=239.255.42.42 VIDEOSOURCE_IP_PORT=5004 # H264 or H265 CODEC=H265 #AUDIO INPUT # NO_AUDIO,USB_AUDIO,FILE_WAV,BEEP AUDIOSOURCE=USB_AUDIO AUDIO_BITRATE=20000 # Bitrate source ./include/getbitrate.sh let TS_AUDIO_BITRATE=AUDIO_BITRATE*14/10 let VIDEOBITRATE=(BITRATE_TS-12000-TS_AUDIO_BITRATE)*650/1000 let VIDEOPEAKBITRATE=VIDEOBITRATE*110/100 #OUTPUT TYPE LIME or IP OUTPUT=LIME OUTPUT_NETWORK="230.0.0.10:10000" # Launch processes echo echo VideoBitrate = $VIDEOBITRATE echo VideoPeakBitrate = $VIDEOPEAKBITRATE case "$OUTPUT" in "LIME") source ./include/nanoencode.sh | source ./include/limerf.sh ;; "IP") source ./include/nanoencode.sh ;; esac
Transmitting
cd ~/dvbsdr/scripts ./jetson_nano.sh
Update - Control from Portsdown Touchscreen
Version 201905070 of the Portsdown Software (currently only available as a Development Release) introduces Control of a Jetson Nano set up as above from the Portsdown touchscreen in H265 HDMI mode ONLY.
To set this up, load the development release, and then edit the file
/home/pi/rpidatv/scripts/jetson_config.txt
with your settings:
jetsonip=192.168.2.113 jetsonuser=nano jetsonpw=jetson jetsonrootpw=jetson lkvudp=239.255.42.42 lkvport=5004 tsoutip=192.168.2.177 tsoutport=10000
You will probably only need to change the 4 jetson lines. After you have done this, use the touchscreen to select:
- Output to: Jetson Lime
- Encoder: H265
- Source: HDMI
Then you can select other settings as required. Testing has only been conducted over a narrow range of SRs and FECs. 500KS, FEC 1/2 is a good starting point.
The Jetson settings will be configuarable from the Portsdown touchscreen in a future release.
Power Draw
- CPU Frequencies at deafult: 0.3 - 0.6A depending on CPU & Network load
- CPU Frequencies at max: 0.45 - 0.9A depending on CPU & Network load
- CPU at max, LimeSDR Mini & C920 at 1MS 1080p H.265 DVB-S2 transmit: 1.8 - 1.9A
GPIO
| GPIO Default State | GPIO Number or function | Header Pin # | Header Pin # | GPIO Number or function | GPIO Default State |
| Example | Example | Example | Example | Example | Example |
