Revision as of 21:02, 3 July 2019 by M1EGI (talk | contribs)
To build the unit you only need to buy the following components from the BATC shop [[1]] and then download the free MiniTioune software.
  • The version 2 main PCB.
  • The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
  • The unit uses an adjustable MCP1826 as the 1v regulator, which can be hard to find.
Parts list and schematic
Circuit diagram / schematic
Parts list
The small regulator module is used to reduce the 12v input down to 5v to reduce power dissipation in the linear regulators. The recommended type is available from ebay - search for "MP1584 step down buck regulator".
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
Setting up the hardware
A resistor between 5.6k and 12K must be fitted between CN2 Pin 19 on the USB module (U6 on the BATC PCB) and ground as shown in the pictures by G7JTT and M1EGI.
G1MEG 180px\G7JTT
On the air
